Digi Pro Amp module Fixed!!! |
Page <1 345 |
byronit ![]() New Member ![]() ![]() Joined: 05 June 2019 Status: Offline Points: 2 |
Thanks for your assistance i have emailed the files as requested. The sub emits a hum possibly the caps are bad , ill will check power supply for ac ripple, any other advise
fmatteo93 ![]() New Member ![]() Joined: 08 July 2019 Status: Offline Points: 1 |
Good afternoon to everyone.
I also have some issues with my DIGIPRO 600M amplifier. Can I receive the electrical schema? Many thanks, Matteo Falchi
ecoso ![]() New Member ![]() Joined: 05 March 2018 Location: devon uk Status: Offline Points: 4 |
Hi, Are you still doing repairs to Digipro amps? I have 2 for you to look at... ed
AudioSystemsEngineer ![]() Registered User ![]() ![]() Joined: 11 November 2013 Location: London Status: Offline Points: 144 |
Hi, who's successfully repaired Digipro modules ?
I've got a digipro1000 on the bench at the moment, SMPS is GOOD, Output FETs are GOOD. Won't start with the O/P FETs in, No swithching waveforms on the FET gates on either channel. I'm about to replace the IRS20957S drivers but seems a bit odd that i'm getting nothing on both channels, so its possible the shutdown is active. LED 1 and 2 are lit, but their function is not labelled on the board or schematic. any help apreciated :-)
mantasel ![]() New Member ![]() Joined: 06 May 2022 Location: Lithuania Status: Offline Points: 1 |
Hi, what could be wrong with Opera 712DX amplifier module? It is from dBtechnologies active speaker. RED LED blinks 7 times and pause, 7 times and thats all... No sound, nothing.. All Mosfets are good, checked, PSU and NTC protection voltages all are OK.. Could be software problem? 24LC256L memory is OK. How to full reset processor, PIC16F689? Could someone repaired it and could Help to me?? https://www.facebook.com/mantaspu/videos/5054032577968008 https://www.facebook.com/photo/?fbid=10220872881747993&set=pob.1118047132 https://www.facebook.com/photo/?fbid=10220872881787994&set=pob.1118047132 |
Page <1 345 |
