  New Posts New Posts RSS Feed - Dimensions for 186...
wusabi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wusabi Quote  Post ReplyReply Direct Link To This Post Topic: Dimensions for 186...
    Posted: 13 May 2006 at 5:29am
186:
What are the angles for all the seperate joins in this cabinet? Are they the same as the 1850?
Also should I be using 15mm or 18mm ply?
SteveSmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveSmith Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2006 at 6:08am
18mm ply trust me. for cleaner sound brace the sides near the exit as well.
theyre the same as the 1850. if you mark it all out on a side cut to size u dont need the angles. clamp n glue is easier an neater than dowels or screws
Edited by SteveSmith - 23 May 2006 at 6:10am
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2006 at 7:28am
some one else said this and i still dont understand!
horn loaded for her pleasure
This page was generated in 0.219 seconds.
