Dimensions for 186... |
wusabi ![]() Registered User ![]() Joined: 28 March 2006 Status: Offline Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 13 May 2006 at 5:29am |
186:
What are the angles for all the seperate joins in this cabinet? Are they the same as the 1850? Also should I be using 15mm or 18mm ply? |
SteveSmith ![]() Registered User ![]() ![]() Joined: 26 September 2005 Location: United Kingdom Status: Offline Points: 25 |
18mm ply trust me. for cleaner sound brace the sides near the exit as well.
theyre the same as the 1850. if you mark it all out on a side cut to size u dont need the angles. clamp n glue is easier an neater than dowels or screws Edited by SteveSmith - 23 May 2006 at 6:10am |
Mark James ![]() Old Croc ![]() ![]() Joined: 15 January 2006 Location: rig side Status: Offline Points: 5304 |
some one else said this and i still dont understand! |
