Diode help |
doller
Young Croc Joined: 19 July 2014 Location: japan Status: Offline Points: 509 |
Posted: 06 September 2017 at 12:27pm |
I have this dead diode physical damage. On it it says 1R 4C I have been trying for over 1 year to get a replcement. Nobody here seem to know what I can replace it with. Any idears what one I can use? It is an old Technics SE 9600. I am not a electronics wizz so simple please. |
Pinyorouk
Young Croc Joined: 31 January 2011 Status: Offline Points: 551 |
Service manual is here: https://elektrotanya.com/technics_se-9600_service.pdf/download.html D509 in service manual is part number RVD10D1 Google brings up:
NTE116 (Standard Power Diode, 600 V, 1 A, Single, 1.1 V, 30 A)as an equivalent. 18 Pence from Farnell UK. I would make sure there are not any other defective components like transistors and resistors as it is unlikely for the diode only to be damged. This diode is in the protection circuit. If in doubt, send to someone with experience in repairing amplifiers. N.B Please don't click the the NTE116 above or here as it takes you to ebay with a part of the wrong type. Edited by Pinyorouk - 06 September 2017 at 2:23pm |
APW
The
diode is fed from a relay that is in turn fed from the mains transformer
secondary, Any standard 1 amp rectifier
diode would work in that position, a 1n4005, 4006
or 1n4007 or similar would be OK.
Edited by APW - 06 September 2017 at 2:47pm |
doller
Thanks guys. APW that is in exacly the position that you mentioned. The cap next to it blew up. big bang. I replced that and it was working fine for about 3 months then the relay started cliking on and off. Traced it to that diode.
Didn't find the service manual. Thanks. Good to know. I understand what to buy now. Thanks again. |
