  New Posts New Posts RSS Feed - Direction of porting for speaker rebuild
charliefreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote charliefreak Quote  Post ReplyReply Direct Link To This Post Topic: Direction of porting for speaker rebuild
    Posted: 20 June 2018 at 5:28pm
Hi all... new member here with a query that I hope someone can help with.
I am building a wall-mounted credenza / hi-fi cabinet that will have built-in speakers. I plan to repurpose the drivers / crossovers from a nice pair of older hi-fi bookshelf speakers that I have lying around. The new enclosures will be similarly dimensioned, but the old speakers were rear-ported. Because the new unit is wall mounted this is not possible.
My question is, will I run into any problems by porting the speakers through either the bottom or the front of the cabinet? Would there be any preference between these two options?
Many thanks
Charliefreak
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2018 at 7:03pm
None whatsoever. Go for it... with pics please!
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2018 at 4:45pm
Wherever the ports can be places furthest from boundaries such as walls will be your friend when designing for the most predictable behaviour. Apart from that crack on. I built HiFi cabs with the (rectangular) ports on top before for something different. I think they have a few birthday cards inside them now but apart from that all is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote charliefreak Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2018 at 11:40pm
Thanks for your responses... I will crack on with confidence!
Post Options Post Options   Thanks (0) Thanks(0)   Quote charliefreak Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2018 at 11:41pm
Thanks for your responses. I will crack on with confidence!
This page was generated in 0.438 seconds.
