Discussing plans for new small soundsystem |
Post Reply | Page 12> |
Lillike_natnek
Registered User Joined: 29 October 2019 Location: Netherlands Status: Offline Points: 32 |
Posted: 29 October 2019 at 2:24pm |
Hey guys, Me and a couple of friends are thinking about building a small sound system. Our focus will be on hosting some small outdoor/indoor events, I’d say for approx. 150 people. We plan on playing different kinds of music such as techno, house, drum and bass, dub etc. Basically it should be capable of playing most dance music styles nicely. Besides, a logical possibility for expansion later on is also desirable. For a first investment, our budget is about €3500 - €4000. We already got our hands on a DSP (Behringer DCX2496, we suspect it will suffice for now) and two 2x1000W amps of which one channel is broken (so we have a total of 3x1000W channels). None of us has built a sound system before, but we’ve been through many many forums. We would like to receive some feedback / thoughts on the following setup; - Subs: 2x Hog Scoop (18LW1400 loaded 1000W RMS@8Ohm) - Kickbins: 2x ES18-BPH (Fane Colossus 18SB loaded 1000W RMS@8Ohm) - Midtops: 2x Lavoce Sistema F153.14N
(Waf153.00: 500W RMS@8Ohm + DN14.25T 80W
RMS@8Ohm) http://www.loudspeakersplus.com/v/vspfiles/templates/driven/pdfs/LAVOCE_Sistema%20F153.14N_SuggDes_RevB.a.pdf OR 2x MT130 (PD121: 300W RMS @8Ohm + BMS4550 80W RMS @ 8Ohm)
Some questions we have:
Any suggestion / input / whatever would be greatly
appreciated! Thanks! Edited by Lillike_natnek - 29 October 2019 at 2:26pm |
Fracture_clinic
Registered User Joined: 01 November 2018 Location: Norwich Status: Offline Points: 113 |
Just a quick note on the mid-tops, MT130 sound weird up close. At Frechtek 25 they only sounded good from 30m back and they were flown high! For 150 people I'd definitely consider something else. Out of the two, go with Lavoce Sistema
DJ-Dulux
Registered User Joined: 24 August 2009 Location: Kenilworth, UK Status: Offline Points: 378 |
Welcome to the forum,
As you haven't built anything maybe consider going for something off-the-shelf to start with, especially for the tops. I was in a similar situation and eventually went for some SoundGear speakers, the R&D is done and for the cash you have it should be possible. Cheers, Dupe...
Dupe...
Lillike_natnek
Thanks! Cool suggestion, with which bass cabinets did you pair them when you started out? We'll definitely keep these in our minds, thing is, building is also part of the fun
Fracture_clinic
Just built a small scoop system so shout me for any build questions when you get stuck in! if you need ofc.
toastyghost
I hate to be the bearer of bad news, but 4000 Euros is probably not enough cash to do anything other than get the wood and components. You need to also factor in cable, connectors, amp racks, and such like. Just to consider that, so the project doesn't lose momentum is a good idea.
Your bass amp will likely cost the best part of 1000 Euro if you're after something that'll let you expand. An XTi4002 even in bridge won't do a lot, unfortunately. If you're considering Orbit 4s, then you should also consider amps from SoundGear too. |
Fracture_clinic
I managed for to build a two-wide for less. Not going to win any awards but it can certainly be done. I think the key point here is expansion. You can buy more amps in the future or sell and upgrade when the time is right. In terms of spending with respect to the first iteration of the rig 4k should be fine. |
Lillike_natnek
@Facture_clinic: Thanks, will do! You care to share some more details about that small scoop system? What other cabs, which amps etc? @Toastyghost: We made an indicative list of costs, with some budget for things such as paint, wheels, cables etc. as well. We figured that 4k should be enough for starting out, doing more investments with time. We won't need the best amps and best dsps in the beginning. Also, we don't mind buying second hand. If expansions happen in the future we can adjust our setups and buy new amps and sell the old ones. Why do you think those XTI4002s won't do much? According to the numbers they should provide plenty of power, or am I overlooking something? edit: additionally, we're figuring out ways to buy components and wood etc. without VAT, and since we're situated in the Netherlands should save us about 20% in costs
Edited by Lillike_natnek - 29 October 2019 at 4:20pm |
DJ-Dulux
I actually went for 4 x Orbit 3 from the same place. Really happy with it, sounds great and looks good too. Dupe...
Dupe...
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
I would also consider using some better LF drivers for sub. The 18LW1400 is absolutely not bad but it can't be compared with the newer generation of drivers.
I also pm'ed you about some stuff, maybe you're interested
Lillike_natnek
Thanks(1)
We picked those because they're available from a dutch retailer, they're relatively cheap and they were in the list of recommended drivers. Which one do you think would be better? I think I can't receive pm's, at least I can't find my inbox on the forum (sorry, new here)..
RiddimKid
Young Croc Joined: 22 October 2006 Location: United Kingdom Status: Offline Points: 847 |
There’s always ligwa’s eco scoops. They cost about £400 fully loaded. He also does a kick bin and top cab now. Could build a solid system, or just one stack of 2 scoops,1 kick bin and 2 tops for around £2600
