  New Posts New Posts RSS Feed - DJ Monitors. The final shots.
 Post Reply Post Reply Page  <12345>
JohnnyPyro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnnyPyro Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2013 at 8:17pm
Tony .. have you tried any marine products? IIRC awlgrip do a pretty tasty laquer, should be harder wearing than the car stuff
Powered by MC2 & XTA
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2013 at 8:24pm
Tony they look brilliant. Are the horns available for sale & what is the dispersion on them?
Edited by Nitz V1505 - 15 May 2013 at 8:33pm
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2013 at 11:14pm
wow they look great Tony..... love the shape and the speakon cutout section top work as allways....
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2013 at 11:30pm
sorry Tony, didn't mean to get carried away :)
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2013 at 11:33pm
only reason for repainting them is if splooge doesn't wipe off easily
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 12:45am
The hardness of the paint isn't the problem. There are two issues. One is that the wood underneath being Flexiply is not as hard as Birch, and although I finished these in Acid Cat, which I used as a propellent for the Silver Metal Flake, I could use 2 pack which would be harder. The cabinets are stiff enough because they are fiber glassed inside. The second issue is the gold paint. It still takes a fingerprint and continues to sink into the ply that I made the speaker grill surround out of. It is more stable on the horns which are Fiberglass, although I painted them with 2 pack before the gold went on. I just need to find a lacquer that won't discolour the Gold. The Gold paint which is straight out an Aerosol can is very strange, It reacts on Acid Cat, which is why I ended up buy 10 cans of the stuff just to get where I'm at. Gold doesn't exsist as normal paint. You can get any amount of car gold paints but they are not the right colour gold. Anyway I will try another idea I have up my sleeve. So it will back to B and Q for the Gold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 12:56am
The Horns are available, It's the Horn I made for the MX900 a good few years back. It's basically a 60 x 40, except the top angle is 10 degrees and the bottom is 30. It has  a 2"throat. I've always had this thing normal horns that point straight out and half of the vertical dispersion goes above peoples heads into the ceiling. This way for a normal floor standing crowd, with a Mid Hi box above peoples head, more of the HF is aimed at peoples ears. That was my reason for doing it anyway. Even in the MX600, although not usually obvious, the HF horn angles down at 4 degrees. You haven't got to stand too far back before you are looking directly down the axis.
peter_p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter_p Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 1:56am
Personally I don't like the colour.
I also feel the spekons look really bad. They don't give me a pro feeling or that I've got something that is very well though out for my cash. The gold grilles behind the ports also look cheap and like an after thought. Also don't like the mount that is holding the bass mid driver in place. Looks like a mis match between a car sub and a PA cab. For me its all glame, but I feel there needs to be a mix of complex engineering to go with the glame.
Take a look at the riders from the top DJ's at the moment and they all spec 2 or 3 smaller line array midtops on a couple of subs per side. The cabs they are specing have a hi degree of engineering to them so they look hardcore from an industrial perspective yet also have great styling.
Treat the design as if it were a tool Tony, but give it a personality.
b grade View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 3:47am
Pretty sure he knows what he is doing on the engineering side of things.  Maybe you don't like the look, but dude has been in the industry long enough to know the physics.  Your comment seems disrespectful.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter_p Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 6:12am
Let me explain this simply. Engineering can have more than one meaning. Some do it with sound, others mechanically. Quite aware that Tony knows sound.
Here's an example of great engineering done with stlye.
I wouldn't care how that sounds if I were a DJ. I just know I would want that next to me to make me look even better than I think I already am.
This example even has curves.
Again, I wouldn't want to hear it, but who ever's stood next to that is really going to look like they know what they are doing. It won't let ya image down and shouts sophistication. Its no wonder L Acoustics, Nexo and D&B are on most DJ's riders for monitors. You and me both know theres no way a system like that should be used for monitoring, but when you ask DJ's why they spec it they say its for looks and its a known quantity.
If anyone out there can bring sophisticated and glamorous levels of mechanical engineering to a speaker cab its Tony.
I have a feeling I'm playing the game on here all wrong and should have lied and said, wow its so amazing. Everyone else I know would have done that.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 6:14am
Nah he's got plenty of other kit to fill that need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2013 at 6:47am
Great news Tony. Ill be in touch soon . Im after a couple for my mud tops which are 15"s so the 2" horn is perfect. Great idea with the dispersion. Also Tony whats the lower cut off for the horn.
Edited by Nitz V1505 - 16 May 2013 at 6:48am
