DJ Monitors. |
Post Reply | Page 123 5> |
phaze one
Registered User Joined: 22 March 2006 Status: Offline Points: 49 |
Posted: 22 July 2007 at 3:08pm |
Hi i want to build 2 DJ Monitors for use in a nightclub. I was just wondering on any recomendations for the type of enclosure and driver to use.
i think 12" drivers are adequate, and a normall sealed or vented enclosure is best, but im not sure what drivers are best to use, as i presume the best monitors have a flat response using only 1 driver and a mid/high compression driver.
any info appreciated.
Rengade Project
Young Croc Joined: 12 December 2004 Location: United States Status: Offline Points: 601 |
You can build or you can get an inexpensive powered speaker eg. tapco or behringer.
MUSIC SWEET,www.myspace.com/renegadeproject
moray james
Registered User Joined: 07 September 2005 Location: Canada Status: Offline Points: 141 |
why don't you consider a dipole set up as shown in this link.
This system is small and easy to build and haul. The dipole radiation pattern will be of use with a DJ set up and the pattern will allow you to focus level on your dance floor.
moray james
TONY.A.S.S.
Our main critria for dj monitors was to build a cab that has to be turned down. Either 15+1 or 12+1 passive . I learnt in the '80's that to make a dj behave himself or herself we would give them good level in the cans and a monitor that was too loud. Nothing elaborate needed. Just a good strong box with a flat response. |
everdark
Registered User Joined: 08 April 2007 Location: Russian Federat Status: Offline Points: 242 |
our deejays often ask to put the djbooth in the front of the stacks.
it's an essential sort of russian economy:) |
phaze one
what drivers do you recomend? i think im going to stick to a 12" but im not sure which is the best driver to give a flat response.
ceharden
A perfectly flat response is not necessarily essential. The ear is very good at compensating itself. For DJ monitors I'd more be wanting something very loud and indestructible. If you build them to have a slightly more aggressive sound they will be subjectively louder, that and DJ's will have probably lost half the top end of their hearing anyway!
If they're for a small booth I'd say a 12"+1" combo but a 15"+1.4" box might be a better plan. Either way you'll want a vented box but it doesn't need to be tuned low. You don't need anything below 60-80Hz in a DJ monitor unless they're a long way from the system. |
TONY.A.S.S.
VPAS
Registered User Joined: 05 December 2005 Status: Offline Points: 1203 |
imo you want something with a narrow dispersion so that all the sound is going directly into their ears
n^2 modulo -P = number wang
TONY.A.S.S.
You can also consider delaying the monitor so that it is in time with whats happening out front. This might seem a bit extreme, But coherence is important. It just depends on how good you want things to be. |
VPAS
how would you go about setting the delays?
ceharden
Laser measures are fantastic for setting delays. Failing that a long tape measure! You just need to know the difference between the distance from the listening position to the difference sound sources.
