Djm 800 |
munkey
Registered User Joined: 17 August 2011 Status: Offline Points: 300 |
Posted: 09 December 2018 at 4:01pm |
Is there any way of updating the firmware or doing a factory reset? Most of the effects don't work on mine and I wondered if this would fix the problem. I've had a Google but I've not been able to find anything of use.
Thanks in advance
Edited by munkey - 09 December 2018 at 4:57pm |
the midtops!
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
I wouldn't advise any sort of firmware update if the mixer's working but has faults. You might brick it.
Go into the service menu and check that the CPU is getting all the correct effects switch signals. Chances are it's missing a few due to a hardware problem. |
North Staffordshire |
munkey
Ok. Thanks for that. Much appreciated
the midtops!
