  New Posts New Posts RSS Feed - Djyves Projects CB(X)-18's, TH-SPUD, Duran, CNC
 Post Reply Post Reply Page  <1 3233343536>
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2014 at 2:23am
Thanks.
Just went on holliday to England for a few days, visited the Wings & Wheels show at Dunsfold park.
Camped in Washington, also been to london.
I've build almost the whole table from drawings I've got all over the place,
But I'm willing to make plans of (almost) everything.
I already have a lot of things I would do differently if I was building a second machine.
Like the Y-axis drive system, it's quite big now, already got ideas to make it smaller.
Anyone interested? In a whole threat with plans and drawings and explanation?
You can always PM me with questions, or post here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2014 at 12:22am
Today I finished the 10 legs of the table with adjustable feet.
First I welded a nut on a 60x60 plate:
Then welded a 50x50 square tube in the 60x60 tube, and welded the plate to the bottom.
Grinded smooth and painted them red (ofcourse the legs are holded by piece of cnc routed wood):
Installed the legs:
The adjustable feet are 100mm round steel plates, I welded a nut in the middle, and welded a piece of threaded rod to the nut.
Experimented with vacuum table, works very well:
The gas struts I ordered were too weak, ordered better ones.
Until then I'm using old batteries to keep the backlash minimal:
Really need to buy a nice dust collector, routing gives a lot of dust.
New 4Kw spindle should arrive this week.
The bottom surface is going to be a 25mm MDF panel, with slots for vacuum routed in.
The vacuum-table will be created in (four) sections that can be switched on or off separately.
Edited by djyves - 01 September 2014 at 12:26am
space-face View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote space-face Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2014 at 12:31am
Routers have a fan that blows dust everywhere. You'll have much less of a problem with dust with the water cooled spindle, they are lovely and quiet too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 01 September 2014 at 11:14pm
Haven't thought about that one, it will be better without a fan blowing the dust all over the place.
4.0Kw spindle arrived. mounten the mount on a mounting plate (not painted yet):
Another one with a 1L coolant bottle for size comparison:
The variable frequency drive:
A radiator I had lying around:
I'm using anti corrosive coolant (with the black painted mounting plate):
As soon as I've got some time, I'll connect the VFD to the 380V and get the spindle spinning.
Edited by djyves - 01 September 2014 at 11:14pm
JACKCO520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JACKCO520 Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2014 at 5:42pm
dear
do you now more about the plans for the 2 x 12 inch horn
regards
jaak
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2014 at 11:39am
I made 1 of the 12'' sections of the 2x12'' + 2x6.5'' tops, dis some testing and measuring, it was quite good. But after that I didn't go on with the design.
I would still like to go on and design, build and test a hornloaded top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2014 at 3:32pm
Did some work on the table, and some routing.
Found some space upstairs, placed the table and glued 25mm mdf panels in place:
Flattened the work surface, used a 25mm bit, routed 2mm deep:
Bought a dust collector:
Was quite useful, flattening created a lot of dust:
Flat working area:
I didn't route the vacuum pattern yet.
For the dust extractor, there is going to be some sort of cyclone system.
Also I made an auto Z-zero tool, just a piece of bare pcb and an aligator clip.
Had some speed issues, reinstalled mach3 and driver, most problems are gone now.
Edited by djyves - 02 October 2014 at 6:31pm
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2014 at 3:51pm
That's actually rather genius!
Where are you at in the process towards completion?
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2014 at 6:48pm
Quite far, here's a list of things I've still got to do:
- Buy a better pump for the watercooling
- Build a cabinet for watercooling
- Build a cabinet for the motor controllers
- Build a cabinet for pc and touchscreen
- Connect connectionbox on Z-axis
- Mount emergency stop buttons securely
- Mount emergency stop poles on Y-axis
- Get aluminum blocks instead of a stack of rings to support ballscrew bearings
- Starting and controlling the spindle from Mach3
- Starting and stopping the dust collector from Mach3
- Start to build some cabinets
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2014 at 11:56am
<p ="MsonoSpacing"><span lang="EN-US">- Buy a
better pump for the watercooling<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Build
a cabinet for watercooling<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Build a
cabinet for the motor controllers<o:p></o:p></span>
cabinet for pc and touchscreen<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Connect
connectionbox on Z-axis<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Mount
emergency stop buttons securely<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Mount emergency
stop poles on Y-axis<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Get
aluminum blocks instead of a stack of rings to support ballscrew bearings<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Starting
and controlling the spindle from Mach3<o:p></o:p></span>
and stopping the dust collector from Mach3<o:p></o:p></span>
<p ="MsonoSpacing"><span lang="EN-US">- Start to build some cabinets</span>
Yeah the last point on your list sure is the key towards putting a dmile on your face! Great work so far and very kind of you to share this!
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2014 at 11:27pm
A few days ago I routed some signs for a friend, result:
At an auction I bought a nice cabinet for the pc, motor controllers, watercooling and power distributor:
At the same auction I picked up 2 C-audio Pulse 2650's:
I've ordered relays, circuit breakers and wiring for the power distributor of the cnc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2014 at 8:05pm
I've been doing some routing on the cnc.
I've build 2 12&1" speaker/stagemonitor:
And cutted all the wood for a friend's Soundcraft SI Expression 3 case:
