DMX XLR to Stereo Jack |
SamV
Joined: 21 October 2008 Location: London Status: Offline Points: 8783 |
Topic: DMX XLR to Stereo JackPosted: 22 May 2009 at 1:24am |
Hello,
How do I wire a DMX cable that goes from 3pin XLR to Stereo Jack? |
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 22 May 2009 at 1:41am |
xlr is pin1 ground, 2+, 3- jack is tip+, mid -, base ground, like with audio.
some units are sometimes wired differently, but that will be specified in the manual. i just gave you standard wiring.
SamV
Posted: 22 May 2009 at 3:28am |
Ah so it's a standard audio style cable :)
Cheers mate |
ceharden
Posted: 22 May 2009 at 3:35am |
Pat, please start checking your facts before posting.
For DMX the convention is 1: Ground, 2: Cold 3: Hot. ie pins 2 and three are reversed with respect to audio. For the jack connection (is it an NJD unit by any chance?) it depends on the individual unit because using a jack connection is non-standard. Try an ordinary audio XLR -> balanced jack convertor. If it doesn't work add a phase reverse (swap pins 2 and 3) and try that. You won't hurt anything by having pins 2 and 3 reversed, it most likely just won't work at all or behave oddly. |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 22 May 2009 at 7:59am |
+1 If it's for a NJD Datamoon it is wired Tip hot, ring cold, sheild ground (I doubt NJD swapped their system for any other products but you never know...). PS are you sure its a dmx input? 1/4" jacks get used for all sorts in the world of lighting (dc output, strobe trigger pulses etc) be a bit carefull if its a bit unknown. |
SamV
Posted: 22 May 2009 at 1:30pm |
It's an Abstract Futurescan II/III Controller which goes XLR to Jack to the first Futurescan II DMX 150 and then stereo jacks between all the heads.
![]() I'm guessing the stereo jacks are for DMX. |
Posted: 22 May 2009 at 10:19pm |
fair enough ... tho doesnt matter either way appart from having the insulation the right colour.... long as 1 goes to 1, 2 -> 2, 3 -> 3 etc its gona make the same connection.
there be a lot of cables in plymouth coloured wrong now...
SamV
Posted: 23 May 2009 at 3:06am |
Well the TRS Jacks won't matter but the XLR to TRS might.
