  New Posts New Posts RSS Feed - do i need hd horns above 186 horns?
C-Audiofreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Topic: do i need hd horns above 186 horns?
    Posted: 20 July 2014 at 8:23pm
if i built 4 186 horns and 4 X10 mid tops would i need HD15 horns between them ?
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2014 at 10:39pm
No they both cover the same range.
kr1sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kr1sounds Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2014 at 10:45pm
depends how many ways hes running it.. 2/3/4 way if you know what i mean
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2014 at 2:00pm
They both cover ~50Hz-130Hz, not much point in splitting it between 2 different cabinets,  just build one or the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2014 at 2:02pm
I think I will build the 186 horns
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2014 at 3:36pm
So these would also be no good for sub bass under 15 inch 3way cabs ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2014 at 3:41pm
My 3ways are tuned to 45hz
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2014 at 6:21pm
186 cuttoff is around 50 (slightly lower with more in a stack). It will beef up the bass, but they are not really made for sub bass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 3:34pm
How many 186 horns would be the equivalent of 1 pair of X1 cabs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 3:46pm
I'm looking for bass bins that will go well both inside and outside and that I can use with my 15 +10 +1 to give the system more bottom end so indoors the 15 of my three way cabs will do kick bass and what ever goes under them will do the deeper stuff but outside would be used with two pairs of them and two pairs of X10 cabs no 15 inch 3ways and possibly later build something else to use it as a 4 way rig indoor use will be set up as 4way and until I build something to go between the X10 cabs and the bass bins outside it will be run 3way
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 6:13pm
G Sub?
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2014 at 6:17pm
Do they go nice and low Like the X1 states it does?
This page was generated in 0.285 seconds.
