Do you know this Project from Beyma ? |
Page <12345 7> |
bitzo
Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Posted: 02 July 2009 at 4:09pm |
Ibex
Posted: 02 July 2009 at 4:34pm |
Looks nice, bitzo!
So your concept is a vented frontloaded horn? I also thought about such a design like the C4 Sub... (original C4 also goes too low) What outer dimensions will your cab have? greez |
bitzo
Posted: 02 July 2009 at 4:43pm |
It's a vented rear loaded horn. check out. I named it Tie Fighter, external dimension about 80x60x50 ![]() |
Ibex
Posted: 02 July 2009 at 5:49pm |
Interesting design!
Looks like an compound horn: Small RLH with a planar waveguide in the front of the driver... |
bitzo
Posted: 02 July 2009 at 6:44pm |
I simmed it like a vented horn not like a compound....more stuff to play with hr ;)
Ibex
Posted: 02 July 2009 at 7:04pm |
Would be interesting, if you will get the same results... |
KenTech
Joined: 05 December 2006 Status: Offline Points: 133 |
Posted: 04 July 2009 at 3:45am |
will 2 x SB15-1 subs go as low as a BPH Loaded with C18ELf from Paudio ? Will this bins, both of them, have higher SPL ? Maybe higher SPL on Kick zone ?
it's 2 x SB15-1 loaded with SN15LF, or SD15 from Paudio versus 1 x Es18 BPH Loaded With C18ELf from Paudio. What do you think ? Edited by KenTech - 04 July 2009 at 3:57am |
KenTech
Posted: 04 July 2009 at 4:06am |
What about 1 x SB18-1 Loaded With Paudio C18ELf Versus Es18BPH Loaded with the same driver, C18ELf from Paudio.
wich one goes lower? wich one has higher SPL ? Where it has higher SPL ? Thanx |
Ibex
Posted: 04 July 2009 at 9:46am |
Hi KenTech! Do you mean the Paudio C18-650 EL? cheers |
KenTech
Posted: 04 July 2009 at 1:42pm |
Paudio C18ELF . It's from the new series. It's a lit bit, if not the same as C18-65o EL. The difference between this 2 drivers is not big.
So, what do you think ? http://www.paudiothailand.com Edited by KenTech - 04 July 2009 at 2:01pm |
Ibex
Posted: 04 July 2009 at 3:56pm |
![]() black = SB18 - PAudio C-18ELF - 231 litre grey = ES18-BPH - PAudio C-18ELF - 302 litre ![]() black = Beyma SB15 x2 - PAudio SN-15LF - 314 litre grey = ES18-BPH - PAudio C-18ELF - 302 litre Well, the RLBPH offer a marginal lower cut-off frequency, I think the big advantage would be in the kick-bass range. I would prefer the 2x SB15 cabs, better effiency and almost the same size as one ES18-BPH... no fear, the dip around 110Hz will not be as deep and the peaks will rise and fall snoother ![]() Although I would advise to make a prototype and compare both by listening! Till now I got no auditory impressions of these RLBPH designs. I only heard the father of RLBPH, the EV MTL-1X, before, and they realy rock your body, but unfortunately no direct comparison to other cabs or different designs. cheers Edited by Ibex - 05 July 2009 at 1:56pm |
Ibex
Posted: 04 July 2009 at 4:11pm |
Handed in later, the comparison of the both RLBPH designs with the original Beyma drivers to the PAudio ones...
![]() black = Beyma SB15 - PAudio SN-15LF grey - Beyma SB15 - Beyma 15P1200Nd ![]() black = Beyma SB18 - PAudio C-18ELF grey = Beyma SB18 - Beyma 18P1200Nd |
Page <12345 7> |
