Do you know this Project from Beyma ? |
Page <1 4567> |
| Author | ||
bitzo
Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Posted: 20 July 2009 at 9:13am |
with this displacement I have to add cone volume to vtc, instead if it's mounted straight I have to substract all the driver displacement. |
mrchay
Joined: 29 September 2008 Status: Offline Points: 565 |
Posted: 20 July 2009 at 10:51am |
Idiot question:
mounting of the driver in this cab - firing into the chamber (magnet in the 'horn' mouth), or other way round? which is the intended design? |
KenTech
Joined: 05 December 2006 Status: Offline Points: 133 |
Posted: 20 July 2009 at 11:02am |
the magnet downwords, beacause eitherwise, it won;t fit.
Ibex
Posted: 20 July 2009 at 11:05am |
Hehe!
KenTech, in that case your old HR version should be able to simulate that cab...
greez
Ibex
Posted: 20 July 2009 at 11:10am |
bitzo, you are absolutely correct!
Do you think that these volume differences will have a big influence on the frequency response/performance of this cab?
cheers
Ibex
Posted: 20 July 2009 at 11:14am |
Thx KenTech, I never tried if the driver would fit reverse mounted...
bitzo, so you will have to subtract the driver volume from vfc.
greez
mrchay
Posted: 20 July 2009 at 12:21pm |
this is what confused me.
incidentally, im interested here because it looks like a good compact sub for a 12v system - if build it as a 12inch-er. Any recomendation for 12inch driver to get the most bang for my buck - i dont want to make the mistake of inefficient car sub drivers again... |
KenTech
Posted: 20 July 2009 at 12:52pm |
ibex, very few drivers aren't deep. I haven't tried, but i've measured with Autocad the distance and it seems like you need a driver no deeper than ~16 cm...
that's realy imposible... :) |
mrchay
Posted: 20 July 2009 at 2:25pm |
hold your horses
theres a new fashion for flat subs - they are only a few inches thick.. http://www.google.co.uk/search?q=flat+sub people with expensive sports cars with nowhere for proper enclosures to go put them behing seats and whatnot.. presumably efficiency is sacraficed... dont really know. they are interesting looking things anyway.. |
KenTech
Posted: 16 August 2009 at 11:42am |
i Own u some Pics. Here they are:
OSB15mm. Super Reinforced SB15 Design ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The box has 17Kg, and the speaker has 15Kg, so total= 32Kg. The speaker is Paudio strongest speakers, SD15. Edited by KenTech - 16 August 2009 at 11:43am |
Glenn
Joined: 01 October 2008 Location: Australia Status: Offline Points: 197 |
Posted: 16 August 2009 at 2:47pm |
Have you compared them to the ES18 that you were talking about. How do they sound?
bitzo
Posted: 16 August 2009 at 5:04pm |
so different beasts I think....regarding sims beyma cab drops lower than a bandpass horn but have less kick but more flat under 120 hz. I'm playing around this tapped horn to get more kicky and less subby ;P
Page <1 4567> |
