Do you need to use a delay with these? |
soundgodwannabe
Joined: 22 January 2005 Location: United States Status: Offline Points: 89 |
Topic: Do you need to use a delay with these?Posted: 29 May 2005 at 9:39pm |
I was reading in the FAQ section where you need to use a delay when using horns. Will I need to use a delay with the HD15's?
Make the soundman mad and I WILL press the suck button for your band.
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 29 May 2005 at 10:40pm |
No, but if you want everything to line up right then 'yes' I'll be honest with you, i've never been able to tell the difference between 18ms of delay but i do set it up like that anyway. After hearing how bad 6th order bandpass boxes were supposed to be i was thinking my system would sound crap, but even if i have no delay it sounds ok. My sub has a 18ms group delay @ 80hz and my HD15's is longer (according to my RTA software in a small room If i have time to do it, i'll play some sine waves and do the 'thing', otherwise i'll plug it in and play on the settings i had from last time
Edited by norty303 |
norty303
Posted: 29 May 2005 at 10:43pm |
Oh, and 'instructions' has only one 'S' in it....
soundgodwannabe
Posted: 29 May 2005 at 11:50pm |
I am using some bass reflex subs now, so I don't do the delay thing. I just set my 2 way cabs on top of them and let it go. If I were to build 4 HD15's, and set my 2 way cabs on top, then how much delay are we talking about?
Dom
Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Posted: 30 May 2005 at 12:21pm |
A bit under 3ms. |
