  New Posts New Posts RSS Feed - Does tapped horn behave same as bass reflex ports?
0krizia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 0krizia Quote  Post ReplyReply Direct Link To This Post Topic: Does tapped horn behave same as bass reflex ports?
    Posted: 17 October 2022 at 10:26am
So im interested in learning about tapped horns. From what I understand, the horn length is a quarter of the frequency they are designed to handle well. If the horn impact the sound waves just like a port in a bass reflex design, then the usable frequency response must me very narrow. Is horn different from ports? If so, what makes them different? What does a 1/4 wavelength do different than a small port, tuned to the same frequency?
Edited by 0krizia - 17 October 2022 at 10:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 0krizia Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2022 at 4:24pm
Is the usable frequency response of tapped horn wider than the frequency response of a normal bassreflex port? I might be bad at googling, but I have yet to find any good Info on this matter, or.. well… I have found some articles about horns but once I see complex math equations I tend to back of and look for something simpler to read.
carlosdelondres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carlosdelondres Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2022 at 5:30pm
Note the author of post #5
Lots more stuff out there of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2022 at 9:26pm
I'd first begin with the basics of designs based on quarter wave propagation:
http://quarter-wave.com/
Tons of stuff here which covers most bases, especially if you read it in order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 0krizia Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2022 at 5:30am
Thank you guys.
Augusts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Augusts Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2022 at 3:41pm
From my experience, tapped horns and bass reflex have different dispersion in smaller rooms - BR fills a smaller room nicely but TH has more of a "throw"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 0krizia Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 11:12am
How can one soundsource make soundwaves behave differently than another soundsource? Soundwaves behavior should follow the laws of physics regardless of soundsource?
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 1:14pm
Generally for a chosen driver an optimal tapped horn will be bigger in volume than an optimal  bass reflex cabinet.
Unsurprisingly the tapped horn being bigger is also louder -
Being louder is often referred to as 'Throw'Thumbs Up
Jo bg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jo bg Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2022 at 5:38pm
Danley patents  are very enlightening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Augusts Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2022 at 9:54am
We tried playing different sine waves in about a 70m2 and the TH had more spots of cancellation that BR. I dono. just saying, thats my experience, maybe its an illusion...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Augusts Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2022 at 9:56am
Horns usually also do not work well in small rooms. We had a party in a 30m2 rooms and we turned the FLH facing the wall, then it worked great
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 24 December 2022 at 12:36pm
Have they been volume matched ?
Maybe the TH excites the room modes more simply because of loudness.
Also maybe it was peaky exactly in the room mode frequency .
I mean I also witnessed this with reflex really filling up a room nicely like it's contained much more within it and pretty even response all around.
This page was generated in 0.578 seconds.
