Dongle problems |
Sheggy
Old Croc Joined: 23 May 2008 Location: London Status: Offline Points: 1991 |
Posted: 13 August 2009 at 2:25pm |
I bought a new workstation to run some software that's a few years old. The software on the old machine was authourised via a 25-pin serial dongle on the back of the old workstation. New machine only has a 9-pin socket.
Will a simple 25-pin to 9-pin connector allow me to run the software. I would ask the company but I no longer pay a maintenance contract so I'm not really eligible for support. Any help greatly appreciated! S |
Wrighty
Old Croc Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
Are you sure the 25 pin dongle is serial and not parallel? The dongles we used on our stuff before we went USB were parallel and most I've seen on other systems are parallel too.
If the end which plugs into the computer has got pins (male connector), it's parallel. If it's got holes (female), it's a 25 pin serial, in which case, an adaptor should work ok. You can get PCI parallel cards and USB -> parallel adaptors, although I'm not sure how well the latter work with dongles. EDIT: Post a photo if in doubt! Edited by Wrighty - 13 August 2009 at 4:16pm |
ALL YOUR BASS ARE BELONG TO US.
Sheggy
Thanks Wrighty - I'll check that when I'm back at work.
S |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Serial Ports on the back of PC's Parallel port If you really do need 25 pin serial port, I would prefer this solution from ebay, Item number:130317401743 |
cravings
i've no experience with dongles.. but i've connected to my sparcstation's 25 pin serial port using a normal (9 pin) null modem cable with an adapter on it with no problems.
Sheggy
Yes, you're right Wrighty! It's parallel and I don't know sh!t from shinola, as they say. Thanks for the pic Lev.
I think I need to get a parallel PCI card for my new machine. Does such a thing exist? S edit: this should work (?) http://www.misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=362013&CatId=2658 Edited by Sheggy - 14 August 2009 at 1:54pm |
Jake_Fielder
Old Croc Joined: 08 October 2007 Status: Offline Points: 4231 |
Sheggy
That'll be Jake_Fielder just back from the pub
Wrighty
That card in the Misco link is PCIe (ie. PCI express). Make sure your PC has PCIe slots (which it should have, if it's a new machine) before you buy. Should do the job fine.
