Double 10" Sealed Enclosure Advice please |
Post Reply | Page <1 89101112> |
APW
The main issue isn’t the change in inductance, its core saturation…. Basically in the "real world" air cored inductor don’t saturate (…. they do but at very very high power levels), as soon as you introduce a peace of ferric material into the inductor core space you no-longer have an air cored inductor and at some point you will hit the saturation knee, at this point your inductor is now non-linear and distortion accrues. The smaller the amount of magnetic material in the core the lower the power it which it will saturate so a small screw will saturate at low power were as a large pump of iron will saturate at higher power levels. …. And then we have Eddy currents in the core to consider! |
Earplug
+1 What I was worried about as well. Just don´t stick any ferrite material in an air core inductor. |
Jack1991
Registered User Joined: 05 February 2020 Location: Bristol Status: Offline Points: 495 |
Yes it is going to be a 12v sound system. I have a Pioneer 8704 4 channel class d amplifier for it. I may get a dsp in the future but im still learning and dont really understand the dsp settings etc just yet. So going to try and learn as i go with it. Will check that link out now too mate cheers
Edited by Jack1991 - 07 May 2020 at 12:00pm |
Jack1991
Update: all glued now. Time for a few ciders!
Then tommorow sand fill and router! Also should i be posting the build in here? I kind of went a bit off topic and now its its turning into the build page for the whole project. Edited by Jack1991 - 07 May 2020 at 4:14pm |
JonB67
Post up a build thread. We all love a build thread. Lots of pics please
Jack1991
Yeh what section is this in though mate?? And for the first time ever i took lots of pics too, dead handy! Edited by Jack1991 - 07 May 2020 at 7:22pm |
JonB67
Either under General, or there's a new projects one under plans. Isn't a special build one, but there probably should be!
Jack1991
Cool cheers!
Jack1991
Right started a New Project thread, here is the link if anyone is interested. Thanks again to everyone who has helped me on it so far too! 😀👍🏼 Edited by Jack1991 - 08 May 2020 at 9:16am |
Jack1991
All set up now. Only thing so far i am struggling with a bit is setting the GAIN on both the subs and mid/tops.
I have tried various different ways which i have read and been told and i find i can have the gain to max without distortion. I have turnt it down to around 2 o clock though as around 2 oclock for the subs was a comfortable level in my garage. And 1 o clock for the mid tops seemed to match. But both could go to max with no distortion. As you can see Min is 7oclock and Max is 5oclock. I would like to know if its ok to have it up higher (even i no distortion) or if anyone has any tips for setting it correctly or any advice on it in general? 🙂👍🏼
Edited by Jack1991 - 19 May 2020 at 8:05pm |
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
The gain is there to match with a wide range of sources, like mixing desks, pré-amps, laptops/iPhone, etc. What is the chain of components you are using as the source now ?
Jack1991
Ah ok so i need to alter the gain if i change the input then?
I am currently using my phone or my girlfriends phone as the input. So aux to rca into the amplifier.
