Double X1 |
Pinheiro
Registered User Joined: 27 February 2004 Location: Portugal Status: Offline Points: 320 |
Posted: 22 January 2005 at 8:16am |
Hi One ? Im on the plan of making some double X-1 more or less like the Nexo sub from alfa rig Ok going to be very heavy and big but 4 double per side and i get lots of low end what is the best way to do that project the ( 2X-1 ) or some diferent plan whiad more results ? let the posts start Yours Vitor |
Timber_MG
Registered User Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
I hope this is for a fixed install. 4X1s are said to be very loud though.
Pinheiro
Thanks for the reply the plan is for take the place off my Beta Max (MTL2 clones )i have 8 Beta max on my big party rig to meke par whiad my 8 HD215 and 12 Turbo 811.3 some times i have some surprises the last was 4000+ peaple on the new year party yours Vitor |
Timber_MG
Righty, so it is a portable rig after all
You must have some strong riggers, but X1 + Bark (think of it as a
slight revision on the HD15 theme, like more horn) are said to really
kick butt (ask ppl who attended the shootout). So yeah, it would work,
but for things that size you might look at fully horn-loaded cabs
anyhow. Like something Roborg is currently toying with (not his club
install, his thoughts about 12+ horns per stack)
There is also always the possibility to think about having a bunch of OEM 12s like what Rog was thinking of doing with his 2x12" design (why does its name always elude me?, not punisher/crusher but ....) Performance in stacks is key to scalability when you're thinking about things this size. Otherwize there is always the option of the LAB, but most people won't be able to summon a whole stack or two of those quickly. |
ben influence
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 59 |
psyco? (iirc?) |
whitehousejamie
Young Croc Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
Yep, the Psycho Sub
Pinheiro
Hi the problem is the MT2 dont keap whiad the HD215 and my main gool is to get some real sub power on the rig the MT2 only go from 45/50 hz to 130hz whiad +- 98/99db w 1 m and the HD215 go from 50hz to 300hz but whiad 105/106 dbw1m for flat the HD gain is -6db for the MT to keap up what can i do ? Make some Martin WSX or Lab horn or ........ you tell me me dream is low from 30hz up whiad at list 103db w 1m yours Vitor
Timber_MG
Well the LAB, WSX and X1 would fit the bill (seeing as you can cross
low), it's just a matter of making sure the system meets your
requirements. It is no use having a monster rig if it only gets out two
times a year, so one has to considder scalability with smaller events,
transport, amping $$$, etc. However if you have a lot of really big
gigs, all of the above might make you happy though I'd say if you can
cross lower, i'd prefer a horn-loaded option)
Anyone still have the drawings Rog put up? @ Alex: what ever happened to the flat pack psychos and the drivers? Edited by Timber_MG |
Lasse Lukkari
Young Croc Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
Do you mean these? http://www.speakerplans.com/roghorn.jpg Edited by Vivo |
roborg
Registered User Joined: 05 July 2004 Location: United Kingdom Status: Offline Points: 1026 |
cute horn, what's the driver? v18-1000 i hope although back volume is pretty voluminous cheers, Rob |
Timber_MG
Nice one (I thought it had one bend less like the bark, just goes to show you how poor memory can be)
One might adopt that topology and add a little length to it for sub application in a large stack, though in a stack the size of which you're thinking of you should hit 40 or even a touch less. @ roborg: 2x12" not 1x18" |
