Driver for 18" scoops |
Jahm
Registered User Joined: 03 October 2005 Location: Switzerland Status: Offline Points: 28 |
Posted: 03 October 2005 at 3:48pm |
Greetings, we're going to build two scoops bass 18" and i just wanted to ask if the plans on the site made for PD1850 would work with FANE XB18" ? or if we have to build the box in a different style? I think FANE 18" xb would be the best for a reggae sound, but do you recommand anything else? thank you in advance J-M |
mans1000
Young Croc Joined: 14 October 2004 Location: Slough Status: Offline Points: 1373 |
Fane XB's would sound very good in them,also Void 18 1000's.I even know people that r still using Celestion Frontlines in them.
Insomnia
Old Croc Joined: 06 September 2005 Status: Offline Points: 1721 |
Yeh Fanes 18Xb's sound the business in a scoop, i had 4!! yeh Celestion frontlines too are good and cheap.. i would say stick with the FAnes thou-classic scoop sub!! cant go wrong! |
Jahm
yes thanks! and if we use wood 19mm thickness,will it influence the sound? because they sugest to use a 18mm thickness,will "1mm" chenge the osund or not? is it important to use exactly the same dimension? because i can buy some marine wood 19mm at a better price. thanks. |
mans1000
I don't think 1mm would make a lot of difference.
Jahm
finally we'll take some 24mm...something heavy you know
