Driver ID PD 12" |
CTN
New Member Joined: 03 June 2018 Location: Wokingham Status: Offline Points: 9 |
Posted: 04 June 2018 at 12:03am |
Hello, I have a PD 12" driver and I can't work out what it is, perhaps someone here can help? It has a 3" voice coil, coil winding depth is 17mm and the re is 5.9ohms. across flats is 320.5 mm. height is approx 135mm, and magnet diameter is approx 170mm On the magnet there is a label marked SLS.1629 20/04 the backplate has a chamfer on it, kinda like a PD912 but with a 122basket. Did PD ever make a 122 with chamfered backplate? or a PD912 with a dodecagon basket (unlikely)? Whatever the case I can't seem to find something that looks quite right on the internet. closest looks wise is probably the pd123c01, however this has a rounded chamfer around the pole piece which my one dose not also the winding depth is 19mm. Looking for a recone kit ideally, but if all else fails will probably buy a PD.122. I will get some pictures soon. Thanks in advance for any potentially useful information. |
cravings
photos?
CTN
CTN
sorry for late reply been busy painting speakers!
thankyou in advance for and help.
PauliePaul
Young Croc Joined: 14 August 2009 Location: Birmingham Status: Offline Points: 1485 |
SLS codes are for prototypes or samples.
Get in touch with Fouad @ PD (if he’s still there!) for specs and parts.
CTN
thanks!
