  New Posts New Posts RSS Feed - Driver ID PD 12"
Driver ID PD 12"
CTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTN Quote  Post ReplyReply Direct Link To This Post Topic: Driver ID PD 12"
    Posted: 04 June 2018 at 12:03am
Hello,
I have a PD 12" driver and I can't work out what it is, perhaps someone here can help?
It has a 3" voice coil, coil winding depth is 17mm and the re is 5.9ohms. across flats is 320.5 mm.
height is approx 135mm, and magnet diameter is approx 170mm
On the magnet there is a label marked SLS.1629           20/04
the backplate has a chamfer on it, kinda like a PD912 but with a 122basket. Did PD ever make a 122 with chamfered backplate? or a PD912 with a dodecagon basket (unlikely)?
Whatever the case I can't seem to find something that looks quite right on the internet.  closest looks wise is probably the pd123c01, however this has a rounded chamfer around the pole piece which my one dose not also the winding depth is 19mm.
Looking for a recone kit ideally, but if all else fails will probably buy a  PD.122. I will get some pictures soon.
Thanks in advance for any potentially useful information.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2018 at 11:08am
photos?
CTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTN Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2018 at 4:07pm
CTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTN Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2018 at 4:08pm
sorry for late reply been busy painting speakers!
thankyou in advance for and help.
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 11 July 2018 at 12:29pm
SLS codes are for prototypes or samples.
Get in touch with Fouad @ PD (if he’s still there!) for specs and parts.
CTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTN Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2018 at 7:34pm
thanks!
