Driver ID |
Post Reply | Page 12> |
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Posted: 31 December 2015 at 2:51pm |
Anyone any ideas what this driver may have been??? Hopefully the design of the rear of the magnet may help identify it?
Came out of an unidentifiable bandpass box in a local bar. Been in there for years. No obvious markings on the driver although hard to tell without cleaning all the crap off it. 4" voicecoil. Cast chassis. Binding posts on opposite sides of the driver rather than together. Pretty hefty magnet - driver must be 10-12kgs.
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
beyma
GOD TOLD ME TO DO IT !!!!!
Dom
Cheers..
That saved a lot of trawling websites. Presumably a 15G400 - will compare it to a PDF..
krazyneil
sounds about right looking at photos on the web
Rich99
Registered User Joined: 21 November 2015 Location: Portsmouth Status: Offline Points: 89 |
Rather than start a new thread, thought I'd bump this one as it's two years old now. Can anyone help identify these and should I keep with them, or replace?
No, I really don't know what I'm doing...
Rich99
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4226 |
JBL 2206 if its a 12" or 2226 if its a 15"---Notice that its bolted into a nice Mega cabinet---What type of cabinet is it and can you post up some more pics of the cabinet please?
Rich99
Thanks Robbo, are the drivers worth keeping or swapping out in your opinion?
Best I can do cabinet wise as the file size was too big. |
Rich99
Just noticed the other cabinet which might be a better picture? They are 15" diameter. |
Robbo
Thanks(1)
Would you believe that is one of my old Mega cabinets from the 1970s--Driver is a JBL 2226H 8 ohm 15" .
It needs to be wired reverse phase as that driver works backwards to all other drivers so make sure that your live wire goes to the black terminal and neutral goes to the red terminal. |
Rich99
I've not checked the wiring, it is undisturbed so will get someone to take a look for me. Being colour blind does throw up some limitations; especially when dealing with electrics so thank you for the warning!
It's fantastically well made and still going strong. Looking forward to sanding it down and giving a refurb. |
Dub Specialist Sound
Old blind man told me, for postive put a little tie in the cable
true story
