Driver rating |
Explicit 2
Registered User Joined: 02 May 2016 Location: Staffordshire Status: Offline Points: 91 |
Posted: 08 November 2018 at 8:56pm |
I apologise if this has been covered before but I couldn't find it.
If a driver manufacturer quotes a continuous rate, a program rate and a peak rate, is the continous rate the same as the rms rate?
'Whether you believe you can or you can't your right' Im here to learn
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
Exactly the same.. no, but close enough for horse shoes and hand grenades.
Edited by Conanski - 08 November 2018 at 9:01pm |
Explicit 2
Thanks
toastyghost
In short, no. AES ratings are the norm now, and are measured using a standard which is freely available to read. It's essentially application of a shaped noise for a certain period. It is not the same as the RMS limit you need to use to prevent coils burning.
