Driver recommendation for hog scoops (4 ohm??) |
Page 12> |
Lillike_natnek
Joined: 29 October 2019 Location: Netherlands Status: Offline Points: 32 |
Topic: Driver recommendation for hog scoops (4 ohm??)Posted: 09 December 2020 at 3:50pm |
Hi all,
Making a new soundsystem with the following setup; - 2x Soundgear Orbit 4 - 2x ES18 BPH (PD186 loaded) - 2x Hog scoop Our plan was to power 2xES18's with one channel of our MC2 E45 Amp and with the other channel 2x hog scoops. Now this amp appears to be suited for 2ohms, would it make sense to go for 2x 4ohm drivers for the hogs (parallel connected)? Seems like this would give a huge advantage output-power-wise, but got some mixed feelings as I don't see many systems using this. This driver for example, has a 4 and 8 ohm version both with almost identical specs. Why should we choose 8ohm or 4 ohm? There's so many options on the forum, we're a bit overwhelmed. Some advice would be really appreciated! Oh btw, we're not looking for the cheapest options, I'd say our budget is around 500€ each driver. Cheers
Edited by Lillike_natnek - 10 December 2020 at 10:00am |
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 09 December 2020 at 7:11pm |
Even the E90 has been seen thermalling, cutting out, running sub at 4 ohm.
Would suggest you get cheap 5K transformer amp, for running 4x Scoops, load them with used, 8 ohm PD1850s, and go from there. |
Lillike_natnek
Posted: 10 December 2020 at 8:22am |
Thanks for your reply, but I'm not sure I understand the issue. Could you explain it a little more? As I understand heat would be the main problem when running one channel of the E45 at 2 ohm, right? Then why does the spec sheet say it is suitable for 2 ohm?
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7508 |
Posted: 10 December 2020 at 10:30am |
this amp will run like this, but it can't be a long term plan. start aiming to get a dedicated sub amp as soon as you can. when you can get another amp for subs the 45 will do a great job on your es18s.
levyte357-
Posted: 10 December 2020 at 10:37am |
Yes mate. But if he is thinking initially 1x amp for sub and kicks, makes me wonder if money best spent elsewhere. If funds are low, I suggest buying Void Infinite 8 mk2, and 8 ohm drivers in the pair of Scoops and ES18s. You will not be sorry, and be happier than with your initial idea. The Void is proven to power 2x 8 ohm cabs, per channel, effortlessly.
Lillike_natnek
Posted: 10 December 2020 at 10:47am |
The amp you suggest practically has the same output power as the E45, why would that one be better? We've already got the E45 as we could get a nice deal couple of months ago. The main question we have now is what two drivers we should get that get powered from the E45 and will be placed in the hog scoop :). I think pd1850's are the most widely used for hogs but my mate says they don't really sound very 'musical', just very aggressive. It's quite hard to make a decision based off of forum posts as so many people are saying different things...
Lillike_natnek
Posted: 10 December 2020 at 10:49am |
At the moment our budget does not yet allow us to build 2 more scoops, I think that's something more for the long term. For now we'll stick to 2 hogs for a while. Could you explain what the 5k transformer amp does and why we would need it for our set up?
Edited by Lillike_natnek - 10 December 2020 at 10:49am |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 10 December 2020 at 2:56pm |
A "transformer amp" is one which uses a (big heavy) transformer as part of its power supply, as apposed to lots of circuitry in a "switch mode power supply" amp. Generally speaking transformer amps are older tech, so are cheaper (now) and easier to repair but bigger and heavier for equivalent output. Your E45 uses a switch mode power supply (SMPS). Cheap SMPS amps often do not do Bass very well and are often uneconomic to repair. There are various pros and cons and opinions regarding the two types of amp but thats the basics
Sypa
Joined: 21 February 2013 Location: Croatia Status: Online Points: 953 |
Posted: 10 December 2020 at 6:55pm |
This has literally been done to death , search google hog driver speakerplans... Personally if i was buying drivers for the hog now i would go with 18ds115 bnc.
Bams
Posted: 10 December 2020 at 7:03pm |
I’m afraid i have real input but as i look at your username it seems we have another Brabander at the forum! Cant have enough soundsystems in the deep south!
Lillike_natnek
Posted: 11 December 2020 at 10:33am |
Well yeah that's kind of the problem. There's so much talking about that it becomes a bit overwhelming for new kids like us. Also there are also many dated posts recommending outdated drivers. I thought the question was specific enough to start a new topic about it given the amp we want to use and the question regarding the impedance. Thanks for your suggestion though, we'd been eyeing that driver for a while as well. I see the nominal power handling is 1700W, I expect running two of those off of one channel of the E45 amp would not be sufficient right? |
Lillike_natnek
Posted: 11 December 2020 at 10:35am |
Haha well guessed! Hopefully after this corona shitshow is over we can serve some nice parties to the south! Are you also owner of a system?
Page 12> |
