driver replacements for EM56 |
Post Reply | Page 12> |
trafficontrol
New Member Joined: 18 October 2017 Status: Offline Points: 4 |
Posted: 18 October 2017 at 9:07pm |
Hey, I was wandering if anyones fitted replacement drivers in Martin audio EM56 ? blew the voice coil on a couple and am looking for an affordable replacement while maintaining or improving on the sound.
If not, anyone tried reconing them and how did that go?
ceharden
Don't think the drivers were anything special.
How much do you want to spend and which speaker brands can you buy easily/good deals?
trafficontrol
was looking at the stock on bluearan and leanbusiness, found some fanes that looked alright but to be honest im pretty new to the game so open to suggestions.
ive got 4 to replace so was looking to buy all as a bundle to get a bit of discount but generally looking to get all 4 for around 250 or so
ceharden
Probably a good idea to have a chat with the guys at Bluearan.
Measure the existing cut-out because what you don't want to do is choose a new driver that requires one a couple of mm bigger, that would be annoying! If you're on a budget and not looking for anything too special, might be worth considering the P.Audio E10-200S. Otherwise it's Fane Sovereign or if they fit the Sovereign Pro. You're not going to get into the range of the bigger brands until you're spending closer to £100/driver. P.Audio stuff is generally pretty good on the value for money stakes. |
MARTYNJONHALL
Registered User Joined: 02 January 2005 Location: Burton On Trent Status: Offline Points: 335 |
I would try the P audio drivers. I have use quite a few and have been impressed with them for the money.
brokenjoe
Old Croc Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3722 |
generally Martin Audio use B&C specially in the wavefront series
error 404
trafficontrol
Cheers for all the help think im gonna go with the sovereigns as theyre back in stock and can get a pack of 4 for 265
APW
the original drivers look very similar to the Celestion TF1020. these are £55.00 from lean-business
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
you could always just send the drivers to rmj and get them reconed
GOD TOLD ME TO DO IT !!!!!
snowflake
unless you have an undamaged driver and want to measure the T/S parameters to find a modern equivalent, just get them reconed. otherwise you may need to start adjusting the crossover to get the same response. I guess the orginal drivers were RCF but don't know if they were a standard model or OEM.
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5227 |
Martin use B & C, Celestion, 18 sound, Clare, RCF and also stuff from the French company who's name for some reason eludes me. I believe the EM series used a mix of Celestion and RCF.
colint
That's the one, you can buy them in maplins too |
