  New Posts New Posts RSS Feed - Drivers for MA WS2 subs
Sparkydude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparkydude Quote  Post ReplyReply Direct Link To This Post Topic: Drivers for MA WS2 subs
    Posted: 05 May 2025 at 6:51pm
Good evening.
Need to put new drivers in a Martin Audio WS2 cab
The current drivers are DLS601. I can’t seeme to get them or recone kits anywhere.
I know they did an amendment to cabinets and called them WS2(A) which used B&C drivers. Does any one know what model of driver they were and whether they are still manufactured?
Many thanks
Con te partirò
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 7:22pm
Originally posted by Sparkydude Sparkydude wrote:
Good evening.
Many thanks
Yours should be the RCF
Have you tried Roy at rmj ?
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 8:53pm
Roy at RMJ can recone pretty much any driver.
Most cones are made by Muller and he can even wind a custom coil if you needed too. But doubt that will be necessary.
Chat to Roy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sparkydude Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2025 at 9:22pm
Many thanks guys. I’ll drop him
An Email :-)
Many thanks!
Con te partirò
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2025 at 7:47pm
If you need to fit a modern alternative, I would probably go with something like the B&C 15PZB100.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2025 at 6:03am
How accurate are his recones to original specs?
Liamodome View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liamodome Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2025 at 9:12am
dls 601 is an rcf l15l601 the recone kits are still available  https://en.toutlehautparleur.com/recone-kit-for-rcf-l15l601-8-ohm-glue-not-included.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2025 at 3:32pm
Had some pd183 done last year. Came back just like the other ones in tse118 cabs with original drivers. Play high like the originals. Sounds like the originals. Been out 9 times at 3 day festivals. Perfect. I know other people who have same experience.
Very confident with rmj. I can recone myself but due to being 183s I sent them to rmj.
w8lm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote w8lm Quote  Post ReplyReply Direct Link To This Post Posted: 17 June 2025 at 11:11pm
DLS 601 is RCF L15L601
B&C drivers are 15TBX100
