Drum fill cab |
GAZ.
Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2428 |
Topic: Drum fill cabPosted: 19 November 2016 at 2:01am |
Thinking about building a drum fill monitor, any recommendations?
100% Earth Moving Bass
cookie-dj
Joined: 09 May 2014 Location: Warwickshire Status: Offline Points: 975 |
Posted: 19 November 2016 at 5:56am |
something twin 15", will knock a drummers head clean off!
maybe something like co-ax 10"/12" on mounts on top?
You can't polish a turd!
ceharden
Posted: 19 November 2016 at 2:37pm |
While a single box drum fill is a nice idea, they do tend to be quite large and don't give much flexibility.
Personally I think it's a better idea just to have a loud wedge (eg 15" + 2") and either another 15" or 18" sub underneath. If you do go for one, you can get away with just two way with twin 15" and a large compression driver or three way by putting a 10" or 12" in the middle. Don't be tempted to go for a small format (1") compression driver. You really need the power (and ability to rip the drummers skin off) from a large format compression driver. As much as I hate to say it, drum fills do not need to sound hi-fi, they just need to reproduce the things the drummer needs to hear loudly! Singing drummers introduce a whole world of pain into the equation but I'd be persuading any drummer that also sings onto IEM's. I work with a couple of singing drummers, both use ears and no wedges. The other alternative is just two large 15"+1.4/2" wedges behind the drummer, then you can use them for any other band members if necessary on other jobs. |
dlyxover
Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1526 |
Posted: 19 November 2016 at 2:55pm |
If you have room a pair of wedges (12" or 15") either side of them with a sub behind the drummer works well I've found.
Lignum_ww@icloud.com
GNKaudio@icloud.com |
GAZ.
Posted: 19 November 2016 at 4:17pm |
I did wonder about a speakerplans DM2, I don't recall ever seeing anyone posting about building one or what they thought of it though?
dj jammin
Joined: 10 April 2010 Location: southampton Status: Offline Points: 773 |
Posted: 19 November 2016 at 5:11pm |
I have built the DM2 (although I altered it a bit but same volume etc) I was very happy with the result.. sounds good to me..
Reverence Sound system
dj jammin
Posted: 19 November 2016 at 5:26pm |
Double post!
Edited by dj jammin - 19 November 2016 at 5:26pm |
GAZ.
Posted: 19 November 2016 at 6:56pm |
I'd imagine it's quite a heavy cab! Any pictures?
