  New Posts New Posts RSS Feed - Dry powder fire extinguisher and electrics
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 02 December 2022 at 5:15pm
Yes it’s got through the paint and rusting away. Problem is that’s inside the roof frame and there’s no way of cleaning it out in there. Even if you spray water in it probably won’t clean everything. Mine also had the added problem of soot from the fire which I’ve done my best to wash off everywhere.I think your best bet is to strip out your interior and jet wash as much as you can. I’m thinking about getting a chassis sprayer and blowing a load of clear waxoil or similar in mine to try and stop it getting any worse.
100% Earth Moving Bass
