DSP input, output, limiters, crossover |
admw
New Member Joined: 14 December 2022 Status: Offline Points: 2 |
Posted: 14 December 2022 at 4:39pm |
Hi all! I have a sound system of 5 ways and I am moving to a DSP (Xilica xp-4080) but I'm trying to understand what's the best setup for it. I have several questions:
Thanks a lot! AD Edited by admw - 14 December 2022 at 5:45pm |
marksantangelo
New Member Joined: 09 June 2012 Status: Offline Points: 5 |
I’ll keep eye this thread
As newbie here to an I’ve bought an MC2 delta 80 with on board DSP an have read the manual but don’t understand how set program an peak limiters with set funktion one 1201’s Also Getting gain structure right coming out of dj mixer Any help or link so can learn an understand this would be great.
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
Thanks(1)
1. Each one of those filter types has a slightly different response profile so the idea is to use the combo that produces the flattest impulse and phase response through the crossover region when combined with your drivers. If you don't know what your drivers response looks like around your chosen crossover frequencies the you should find out, but to have the least negative impact even order LR crossover filters sum flat and steeper crossovers offer more protection which is important in pro audio, so 24db/oct filters are a good place to start. 2. Yes the amp gains should be all the way up because that is the position where it matches the rated input sensitivity. If you turn the control down then the voltage required to drive the amp to full output goes up, but most of these controls are not calibrated so there is no way to know just how much that will be. 2a. Turning down the controls on a power amp does not in any way reduce the amount of power it can generate. 2b. In most cases the subs in a system are going to be the limiting factor and as you go up the frequency bands less and less power is needed. But it's hard to know with a new system exactly how much power is needed in each band to produce balanced sound because it depends on the speakers and music genre and operator preferences. You don't want the mids and highs to continue getting louder once the subs are out of gas so really once you figure out the signal level where the subs are limiting then all other bands should also limit at the same time. 3. That is going to depend on the signal levels needed to drive the amplifiers, so no way to know until you figure that out.
Edited by Conanski - 16 December 2022 at 1:00am |
