  New Posts New Posts RSS Feed - Dual 12+ HF
Dual 12+ HF
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2021 at 5:42pm
@toastyghost
1m is indeed to short of a distance, last measurements I was bound by the weather conditions. Going for a larger distance would give me problems with other boundaries. In the coming weeks, weather is improving which gives me more freedom. A 244x122cm piece of wood will probably do the job as a reflective underground. For now that with a large grass field is the best I can do. A large concrete surface would be ideal, but not much of those in the neighborhood.
In the above pics, the IR window is set at the default values. So 125ms left and 500 right.
Btw thanks for that PDF, have not read that one yet Smile
Edited by smitske96 - 23 March 2021 at 11:34am
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2021 at 6:32pm
Which 21" driver did you go for in the end?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2021 at 8:53pm
I settled on the SAN214.50. The 215.30 was still very hard to get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 2 minutes ago at 10:59am
Quick update:
Getting the tuning frequency a bit higher to around 70-80Hz is very difficult with the current port layout.
So for now I am going back to panels that close fully at the front, and drill or cut the ports in to the panel (like the T24N).
Also busy with the bracket for the DCX464 and HF950 horn. I can't mount the HF950 just at the front due to the weight. And not only an the entry due to the extra ringing of the horn if its floating free in the air.
