  New Posts New Posts RSS Feed - dual 12 mid high design
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Topic: dual 12 mid high design
    Posted: 09 October 2012 at 10:05am
Hi guys. I am designing a dual 12 mid high cab similar to the x12 for the drivers I have. is there a difference whether you place the comp at the centre or at the top of the cab. the cab is going to sit on top of 3 tham15 per side.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2012 at 10:09am
No, not really. There is coupling of the two 12" drivers when they're next to each other but, most of the time the HF unit being moved in between them is for aesthetics or if you're trying to achieve a D'Appolito arrangement. (Google it and you'll see).
bcs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcs Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2012 at 12:17pm
Hi djeddie. so the d appolito arrangement has no benefits just looks.
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2012 at 4:44pm
Anything that brings the different sources closer together will give a more coherant sound, I think it is the old wavelength rule that the distance between drivers should be less than the wavelength being reproduced.  So for your 12" it would be the wavelength of the highest frequency before going to the CD (prob in the 1k6 Hz range).
Also the total cab height will be reduced if the hf element is between the mids, as the mid frequency will hopefully not be affected by being partially obscured.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2012 at 8:44pm
It does have benefits... as said above really.
