  New Posts New Posts RSS Feed - Dual 12" w-bin
Dual 12" w-bin
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2012 at 2:35am
"Hm, LAB12's looks nice, but, they have very low sensitivity :/ "
Not in a horn, they don't.
"Any sugestions about another 12" sub bass drivers?"
The mouth of a TL5050 is tiny, don't expect sub bass out of it no matter what driver you put in it.
djk
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2012 at 10:58am
Originally posted by bedris bedris wrote:
Hello everybody :)
Today I got a pair of Electro Voice TL-5050 (also known as "big bertha" or "jumboo") but, without speakers :/ Can you suggest some 12" bass drivers for those boxes?
simple builder plan (pdf)
these was called EV Sentry IV wernt thay? i got 1 if i remeber right i loaded it with delta 500lf
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2012 at 12:37pm
At 50hz a direct radiator box of the same net size will have 10dB more output.
The horn will have more output in the 300hz~400hz region.
If you want to try different drivers in Hornresp
Cut-Off Frequency=50hz (hyperbolic-exponential T=0.6)
Throat Area=81 sq. in.
Length=53 in
Mouth Area=769 sq. in.
Front Cavity=130 cu. in.
Rear volume=1.7 cu.ft.
Original EV driver (two 12s)
Fs=45hz
Qms=9.5
Qes=0.215
Qts=0.210
Vas=5.06 cu. ft.
djk
teeboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2012 at 6:53pm
delta 12 lf 4ohm version really good if you like punchy bass got them in my tl5050's and they sound good x-over at between about 51-55 hz -  250 hz did have them at 410 hz to give a bit more mid, but only when i was running 18xb's under them, hope this could be of help.
Laurin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laurin Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2012 at 8:03pm
No this is a rendering from a EAW BH-882 "Bertha".
The user "Retrophonic" from the waveboard techtalk posted it a while ago in a thread:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2012 at 7:05pm
so are the ev tl5050's the same as ev Sentry iv ??
Edited by Dub Specialist - 22 May 2012 at 12:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 12:39am
djk...do you know what driver is the nearest the the original  Ev driver then??? by anychance..
thanks
Fs=45hz
Qms=9.5
Qes=0.215
Qts=0.210
Vas=5.06 cu. ft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 1:41pm
Originally posted by fuzzylogic fuzzylogic wrote:
My Mate has a pair of these, 2x12 EV Centaurian or something. Kick like a mule.
does yu mate want to sell them by anychance looking for 1 ..cheers
This page was generated in 0.061 seconds.
