Dual 15 + coax |
Page <1234> |
dlyxover
Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1526 |
Posted: 25 July 2021 at 9:44pm |
looking very tidy, keep up the good work.
Lignum_ww@icloud.com
GNKaudio@icloud.com |
kipman725
Joined: 02 September 2020 Location: Warrington Status: Offline Points: 231 |
Posted: 26 July 2021 at 3:53pm |
There looks to be some scope for reducing the depth of the box if you have enough internal volume for the bass drivers?
doober
Joined: 03 January 2006 Location: Cornwall UK Status: Offline Points: 1123 |
Posted: 27 September 2021 at 8:49pm |
This was supposed to be a quick project, but then I had a really busy summer and no spare time.... back on it now though.
I put the drivers in for a test ![]() A quick outdoor measurement ![]() A quite worrying dip around 500Hz. I tried moving the mic around, disconnecting one driver, adding and taking bits of box, and then realised the obvious point that a half wavelength of 500Hz is pretty much the diameter of a 15" driver, which I was listening to from the edge. I modified the baffles and moved some bits in the box ![]() Another measurement ![]() That's reduced the problem. I need to do more measurements when the weather is good enough, but I think it looks promising. I did a measurement of the mid section ![]() I'm thinking a 24dB/octave high pass with the -6dB around 600Hz should be okay. |
Blahblahblah
jazomir
Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1759 |
Posted: 28 September 2021 at 9:25pm |
Slightly off topic, but I came across this the other day - Bennett Prescott sales manager of B&C with a new 2x15 + horn design. Bit (?!) big for pole mounting but sounds very good via utoob - amazing that that it doesn't have any noticeable horn sound on vocals possibly like the Celestion aperiodic driver that removes any crossover artifacts in most of the vocal range.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 28 September 2021 at 9:36pm |
It’s probably more to do with using a bloody massive horn that was explicitly designed around the (very good) driver attached to the end of it, by proper engineers using top-tier tools such as FEA-based optimisation
jazomir
Posted: 28 September 2021 at 11:17pm |
Still, nicely done and not too dissimilar to the JTR 215RT speakers with the co-axial HF driver.
Keen
Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1271 |
Posted: 29 September 2021 at 12:40am |
great to see they made that horn, thanks for sharing
doober
Posted: 01 November 2021 at 7:46pm |
More progress. I now have 2 boxes. Both have had 2 coats of paint sprayed on and are awaiting a gentle sand and 2 thick coats of paint. I did a test with pole mounting an empty box
![]() The pole is a K&M adjustable with an M20 screw on the base and the expanding ring lock on the top. There is a bit of sway at full extension, but that is to be expected. A single punisher as a base gets the top box just high enough, I will always be using at least 2 though. I didn't like the idea of a surface mounted pole socket, so I knocked this up out of 3mm steel ![]() It has an M20 nut welded inside, and fixes with 6 bolts into the horn/driver chamber and 2 through to the exterior with a plate on the outside to spread the load. I had hoped to have the boxes finished ready to use for a couple of gigs next weekend. Unfortunately I can't get another DCX464 driver in time, there doesn't appear to be any stock in the UK. |
Blahblahblah
Teunos
Joined: 23 November 2008 Location: The Netherlands Status: Offline Points: 1832 |
Posted: 20 July 2022 at 1:21pm |
Hello Doober,
Did you finish these boxes by now? I'm very curious to the results of this design
Best regards,
Teun. |
doober
Posted: 31 July 2022 at 8:59pm |
![]() They are finished. I've been using them since December for live music, 2-400 capacity events indoors and outdoors. I like them. The midrange is very clear, the boxes are light enough to get up above head height on a pole. The coax drivers are very efficient, and could easily keep up with way more than the 15s I am using. I do like headroom in the mid and high though. The 2 boxes work well with 4-8 punishers, crossing over around 90Hz. If I used some upper bass boxes between them and took the crossover up to around 180Hz I could get a lot more out of the 15s. |
Blahblahblah
cobrasneverdie
Posted: 05 August 2022 at 1:32am |
Is there a reason for choosing b&c over bms for crossing that low? My bms 4592nd loads incredibly well all the way down to the horn cutoff on a massive 225hz multicell.
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 05 August 2022 at 10:54am |
Why did you chose that specific 15 inch driver? To me its a shame using top of the line compression driver with a budget 15.
Page <1234> |
