Dual 15" ported Enclosure for Reggae |
BassMon
New Member Joined: 24 July 2019 Status: Offline Points: 2 |
Posted: 24 July 2019 at 1:06pm |
Hi, I'm designing a dual 15" ported enclosure to support 4 scoops which are 636mm wide per each.
I want to make it 1016mm long and stack two of them horizontally above the scoops. However, many dual 15" enclosures for reggae/dub have a shorter horizontal length somewhere around 940mm or even less. Do you see any problems when stacking with standard sized bins?
Edited by BassMon - 24 July 2019 at 1:07pm |
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
Thanks(1)
You can design the bin any dimension you like providing the internal chamber equates to the proper size requirements of the loudspeaker(s). Best Regards,
