  New Posts New Posts RSS Feed - dual emerald/w levan extension project
parabox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote parabox Quote  Post ReplyReply Direct Link To This Post Topic: dual emerald/w levan extension project
    Posted: 30 March 2017 at 9:36pm
working out modeling an extended  version of emeralds  with  extensions  that break  down   the goal is to have no individual piece weigh over 300 lbs     with at least one  truck pack friendly demension a low corner of 25-20 and the must fit through  your average door
T-Bone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bone Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 12:29am
Did you ever get this Emeralds started? Half Bertha is 22" high and 60" long would fit through ordinary doors. They would be easily lifted with a dolly under to move them around. I am sure there are drawings on the net you can copy build a full size Levan horn in half or broken down with nuts and bolts to secure full size. It can be done I am also thinking about Emeralds with extension but using an 18" neo woofer from Faital Pro specifically the 18HP1022.Big smile
BASS, how low can you go!
