  New Posts New Posts RSS Feed - EAW BH760
EAW BH760
Capitan Planet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Capitan Planet Quote  Post ReplyReply Direct Link To This Post Topic: EAW BH760
    Posted: 26 November 2008 at 6:29pm
Hey
Have any one knowledge about interior of this cabinet, I gona make for myself something like this but it's very dificult to find what there is inside- J mean construction, not speakers
can i please for some photo of interior or simple draw how it looks inside, if someone have plans of BH760 it will be wonderfull
Thanks
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2008 at 6:33pm
Moved to relevant section...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 7:58pm
Here is how it looks inside.
Sheggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 8:49pm
Nice.  29-150 Hz. Do you know what drivers this cab uses Marjan?
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2008 at 9:43pm
from the photo, its really easy to copy it with good results, only if the drivers are available and not OEM's for EAW.
Trace all of the edges, print it same size of the BH cab on a plotter
Edited by djstefanos - 27 November 2008 at 9:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 2:58am
Eminence OEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 5:44am
Looks like a delta pro 12
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 5:20pm
Ciare SW will kill in those boxes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 10:19pm
mmmm, thats cool, i've been thinking about this cab a while now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2008 at 10:47pm
A company here has 6 per side. Great boxes. They are covering up to 20 000 people with them.
Here is a vid
http://www.youtube.com/watch?v=Xh-0Gc1d3jc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2008 at 3:01pm
Just what I was thinkingBig smile.
mxlemming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mxlemming Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2009 at 3:58pm
Hi,
First post on the forum. My name's Dave, a third year mechanical engineering student at uni. I like speakers, a lot, and do a lot of techying and rigging for gigs at uni, but have never done any audio engineering stuff except what I have learnt perusing forums... It's kind of become an obsession.
I'm playing about with Hornresp, learning how it works etc, with the aim of spending a few weeks this summer building myself a little PA, and perhaps, if I seem to get on with it, going into audio... It seems that modelling this cab in Hornresp doesn't work -  segment 2, the first section in front of the speaker which seems to basically be two paralell walls gets the Cir<1, invalid form. The output results are then clearly garbage.
The idea was I'd try and model a few things that have been observed to work well, then when I seem to be able to create meaningful results fairly reliabley move onto designing my own stuff/playin about with AkAbak.... which currently seems inpenetrable.
Basically:
ciare 12sw params (seemed like a fairly likely choice and someone above said it would kill in this box...
S1 = 360
s2 = 375
s3 = 400
s4 = 750
s5 = 2625
All set as con (but gave equally retarded results wen I set it as exp)
Speaker set as offset.
All of these are measured off the screen with a scaling ruler. for the EAW BH760.
Where am I going wrong?
