  New Posts New Posts RSS Feed - EAW BH760
EAW BH760
 Post Reply Post Reply Page  <1234 5>
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2009 at 5:13pm
Remember that BH760 is using two drivers in one box and 2625 is a way smaller number than the actual boxes are. This is now just out of my head (an not at my pc now) but numbers should be a lot bigger.
mxlemming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mxlemming Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2009 at 8:11pm
2625 (cm^2) = 28"*15"*2.5*2.5...ie half the enclosure. I was assuming a symmetry between the two and that although it would have an effect on the low end response it wouldn't be ridiculously drastic.
The numbers you put in ARE areas, cm^2 right, like it says in all the instructions?
Also, if one is building horns like this that are expanding linearly, rather than conically, what is the protocol?
I get the impression that it is meant to be 107dB right down to 29Hz (-3dB) from the EAW website. I was getting it down to about 85dB at 30Hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote mxlemming Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2009 at 8:31pm
http://www.speakerplans.com/forum/wanted-true-subwoofer-horn-design_topic26270.html
Maybe ignore my posts
Apparently it is in fact unlikely a BH 760 goes down to  29Hz at 107dB/watt, if you look at the graph there for the kf940 - even bigger and in a stack of four, which looks remarkabley more similar to the output I was getting (mine was uglier and bumpier and lower power mind).
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2009 at 9:31pm
Originally posted by mxlemming mxlemming wrote:
Hi,
First post on the forum. My name's Dave, a third year mechanical engineering student at uni. I like speakers, a lot, and do a lot of techying and rigging for gigs at uni, but have never done any audio engineering stuff except what I have learnt perusing forums... It's kind of become an obsession.
I'm playing about with Hornresp, learning how it works etc, with the aim of spending a few weeks this summer building myself a little PA, and perhaps, if I seem to get on with it, going into audio... It seems that modelling this cab in Hornresp doesn't work -  segment 2, the first section in front of the speaker which seems to basically be two paralell walls gets the Cir<1, invalid form. The output results are then clearly garbage.
The idea was I'd try and model a few things that have been observed to work well, then when I seem to be able to create meaningful results fairly reliabley move onto designing my own stuff/playin about with AkAbak.... which currently seems inpenetrable.
Basically:
ciare 12sw params (seemed like a fairly likely choice and someone above said it would kill in this box...
S1 = 360
s2 = 375
s3 = 400
s4 = 750
s5 = 2625
All set as con (but gave equally retarded results wen I set it as exp)
Speaker set as offset.
All of these are measured off the screen with a scaling ruler. for the EAW BH760.
Where am I going wrong?
Ok, now i am at home so can explain a bit more.
S1 should be the cross section area of the baffle opening (how do you came up with a 360 figure?)
S2 should be the cross section area at the first 180 degrees bend That should be way more than 375)
S3 should be the cross sectional area at the second 180 degree bend
and
S4 should be the mouth area ( and that is around 4000cm2 mark IIRC)
That 29Hz figure is maybe achievable for BH760 but only in a big group of boxes (maybe 8) and again that will be at least 3-6 db lower than its sensitivity in the 40-90Hz region. But that is very usable amount anyway for any type of contemporary music material.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2009 at 9:19am
similar product eaw dcs-2 sub
anatomy...
http://speakerplans.com/forum/eaw-dcs-2-photo-insaid_topic18243.html
Com4tee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Com4tee Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2009 at 11:52am
What we do not know here is:
1) are they really Eminence delta pro 12 speakers?
2) the throat dimensions...
part of the diaphragm is "apertured" and it is clearly seen on the foto of 760.
The rest can really be measured from the photo. I will trace this in google sketchup and publish my approximation of dimensions if time allows.
Can anyone help with above questions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Com4tee Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 12:24pm
Hi There!
As I told I did some experiments with hornresp, pretty much the same stuff that mxlemming did.
1. I have made the picture "straight" on photoshop before taking any measurements. It was photographed form an angle and it needed quite a lot of perspective correction at down left corner.
2. I have measured the box in sketchup. It is here. Should be quite presice.
http://picasaweb.google.pl/barykent/Temporary#5377192781337354098 <all data im milimeters, plywood thickeness around 20 mm.
3. I assumed that throat chamber entrance would be letterbox covering 70% of diaphragm.
4. I tried it with Delta Pro 12 and it produced acceptable results
It will not give much output under 30 Hz... -8db off the max sensitivity. Sad...
Here are the settings/SPL Chart/Phase Chart.
Could anyone revise my calculations?
Could anyone recommend other 12" drivers that could go lower (at cost of peak sensitivity?)
I think of building 2 such/similar packs for my garage cinema/DJ PA project
Do you think <from predicted charts> Delta Pro is the driver EAW really puts in this sub - or it is a custom version?
The EAW box seems to be somewhat "generic". Presise measurements showed quite a lot of even or nearly even values like 1 meter, 20 sm, 15 cm... all to perfect for what's comming from phisycs modelling. Do they just experimented with a set of "shelves"?! Lets put 1,5 meter now and see if it works better approach?
PS.
Edited by Com4tee - 03 September 2009 at 12:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mxlemming Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 4:24pm
Originally posted by Com4tee Com4tee wrote:
Hi There
PS.
Yeah, you have basically redone what I did, more precisely - I didn't bother too much with correcting the angle, just measured it and made rough corrections based on experience of photoing stuff at wierd angles.
I also thought at the time hmmm.... not much effort has gone into this, all the dimensions seem to be 10, 20, round numbers, just a case of getting the longest posible horn into the smallest possible box, but hey, noone else seems to make them and by accounts they are fairly good?
I also got a similar plot for eigth space 0.5pi, but I was unimpressed with the half space - which I now realise is a kind of fundamental limitation of horns. Remember eigth space is similar to a large conical horn extension. This horn has a mouth far too small, redesign so the opening is on he largest face may help if your not going to stack loads of them.
I also used params for a Ciare SW12 following someone earlier in the thread, which apparently is invincible, and pretty cheap.
Frankly, you'll be more proud of yourself if you don't copy it and invent something of your own. I now have a sketchbook of ideas, and would be building if I could decide on which one I want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Com4tee Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 5:11pm
I have done already couple of smaller projects like ported TL subwoofer that are heavy to predict before actual build... sometimes it was a success http://www.youtube.com/watch?v=VpHczDULOYo and sometimes not... Bazooka was quite easy actually since is a traditional ported box...
It is impossible to just copy EAW design since we do not know what driver goes well with the design <Delta Pro does not>. What I seek for now is adapting the EAW box layout to some reasonable stock speaker. It is not just copying... more like reverse engeenering...
To use Delta the S1 must be 2 times bigger... the rest can stay similar. S1=600 then we get nice flat SPL response from 25 - 45 Hz @ 110 db... then it goes rapidly up to 130... Not an ideal situation but if crossed around 45hz with -12db it shall work for the Infra frequencies...
I will experiment on Ciare soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Com4tee Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 5:12pm
BTW could anyone measure T/S of the 760 orginal driver? Just out of curiosity I would like to model it in hornresp and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 7:33pm
to Com4tee
please
give plan with side\top
Post Options Post Options   Thanks (0) Thanks(0)   Quote Com4tee Quote  Post ReplyReply Direct Link To This Post Posted: 07 September 2009 at 1:36pm
TDA-Audio - the box is 30" x 30" x 45" so the depth is 30". The rest you can see on the pictures. I have no other drawings, but this info is just enough to modell it  / redesign for avaliable drivers.
