EAW BH760 |
Page <1 2345> |
| Author | ||
Centauri
Joined: 29 November 2004 Location: Newcastle Aus Status: Offline Points: 1792 |
Posted: 08 January 2011 at 11:04pm |
The Xmax of the Delta is 4.8mm, so 9mm is way too much. For any box, if you want to reach sub frequencies with decent power handling, then long excursion drivers are a must - no way around that. Off-the-shelf drivers with the sort of parameters that Marjan mentioned before are around, but not very cheap - some of the Shenzhen Ande speakers from China look good for the money, but unsure of long term reliability, and it depends on whether you can get hold of them anyway. |
Com4tee
Joined: 02 September 2009 Location: Poland Status: Offline Points: 23 |
Posted: 09 January 2011 at 5:01am |
Centauri, I thought I could push it to physical limit of 13 mm. http://eminence.com/pdf/delta-12lfa.pdf Probably distortion would be high since we are out of linearity window, but speaker shall survive. Right or wrong?
Com4tee
Posted: 09 January 2011 at 5:14am |
MarjanM I plan to make 2 boxes each 2 speakers. total 4 speakers. I believed that 2P in offset driver section in hornresp means two speakers connected in paralell side firing into the horn. Am I right? What parameter makes you say there are 4 boxes? |
Centauri
Posted: 09 January 2011 at 5:15am |
The emphasis should be on SOUND, not speaker survivability..... operation outside the linear area will result in increased distortion, which is something that should always be avoided.
In any case, the predicted excursion outside Xmax will not be accurate due to the non-linearities - more and more voltage will be required to push the cone further due to less and less voice coil in the gap. |
Centauri
Posted: 09 January 2011 at 5:19am |
You are modelling in 1/8 space, which is equivalent to 4 boxes sitting on the floor. |
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 09 January 2011 at 12:44pm |
Exactly, you should model in 2pi not 0.5.
Com4tee
Posted: 09 January 2011 at 1:22pm |
Hmm I thought that I'm simply putting my sub into the corner of a theoretical room, where it is going to be used in fact, rather than modelling 4 boxes in open cosmos... I must be missing something... can you explain little further, or point me to knowledge source on that?
MarjanM
Posted: 09 January 2011 at 1:30pm |
That is actually same. One box corner loaded have almost same performance as 4 boxes stacked in one pile on the floor.
Com4tee
Posted: 17 January 2011 at 1:53am |
I have edited my orginal post with summary of your remarks. Thanks for them. Taught me something. Ciare 12.00 SW seems to be great choice for the box (dug it somewhere in kf940 posts). Still not what EAW claims to achieve, but waaay better. I suggested enclosure changes to make it compatible with Ciare. I will try to swap my LFA's for Ciare in the future, unfortunately they are not that popular, so getting them cheap/used is rather impossible
Drift_Rob
Joined: 21 April 2021 Location: brasil Status: Offline Points: 3 |
Posted: 28 April 2021 at 4:17am |
Hello friends, someone here has already done or knows the details of EAW730, can you help me build one based on it ??
T-Bone
Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 297 |
Posted: 25 June 2021 at 12:20am |
I think the new Faital 12RS1066 will work with this sub. Old design but can be revived with a new set of Italian 12" woofers.
BASS, how low can you go!
citizensc
Joined: 16 October 2015 Location: Perth,Australia Status: Offline Points: 547 |
Posted: 25 June 2021 at 1:04am |
I have been looking at the 12rs1066, I am tempted to design a sort of 'punisher v4' with it, not that I would call it that.
https://www.facebook.com/voyager.system
@voyager_soundsystem |
Page <1 2345> |
