EAW KF750 handle placement |
smoore
Young Croc Joined: 30 March 2011 Location: N.Devon Status: Offline Points: 937 |
Posted: 18 May 2020 at 9:34am |
Hi guys,
Just acquired a couple of KF750px from an install with out handles, was hoping someone with access to some could take measurements of where the handles sit and roughly how deep they are. There are some *hard to confidently read* measurements on the data sheet but don't want to cut the area then realise my handles are too deep or i've cut straight into a critical brace or something. I interpret this as a handle placed 7.28" from the front, 6.44" wide and 10.87" tall but am not sure. I also wondered whether the rear handle was crucial for those nasty lifts. Any help much appreciated! Sam
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Looks like a H1070 handle (penn elcom), if you use that one for measurements you should find the right place.
lickweed
Old Croc Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
just cut out where handles are placed in plan and you gonna be fine(front ones), there is nothing there.
http://www.liquidsound.co.uk/
Finjby
Registered User Joined: 19 January 2016 Location: Shropshire Status: Offline Points: 74 |
Lifting 750's to head height is ideally a 3-man operation minimum...especially if the wheel board is on. One man either side, and one man helping gain height and front tip onto subs. That's where the little pocket handle comes into play as it's another grab point from the side. (The bar handle is at the centre of gravity point)
I guess the reason EAW did this was because the rear of the cabinet is very narrow, leaving no internal room to locate a full bar handle. Is it essential? No, but it really helps manuvore a weighty, deep and slightly awkward cabinet! Have you considered a sprung flightcase handle as an easier get-around? All the best
smoore
Thanks guys, actually it was a super tight fit! There's a horizontal brace running from rear to front with a recession just where the handle is on the plans. Putting the handle anywhere other than here you'd have to chop out a chunk of the bracing.
Gonna have a think about the rear pocket handles, there is enough room for a small handle but not loads. |
smitske96
Nice job!
Calum
Registered User Joined: 30 June 2013 Status: Offline Points: 12 |
I have got 6 of these and thinking of doing the same, can you confirm if the measurements above were correct and the ones you used? thank you
Edited by Calum - 20 December 2020 at 10:32pm |
smoore
Hiya Calum, as far as i remember my measurements matched up to the plans online but take it slow and keep checking when you cut; There's not much extra room front-back for the handles.
Calum
thank you smoore
