Ecler Sclat 100, Sclat 200vs review |
Post Reply | Page 12> |
opus jody
Young Croc Joined: 06 June 2006 Location: United Kingdom Status: Offline Points: 1246 |
Posted: 18 August 2010 at 10:28am |
Even better that 1 mixer out of 2, how
about trying to get 2 good mixers out of 3? quick test shows 3 of the ALPS faders a
little scratchy, and the crossfader needs replacing. all pots, switches & everything else
are absolutely fine. Good physical condition. Reeeeezult. Then a test of padded vs non padded on the
ecler sclat: Sclat No.3 arrived 1st, the one
with the psu. I’ll have to go back & re-test that,
with the test subs this time. Edited by opus jody - 07 November 2010 at 11:08am |
Improvised Hardware Music http://vimeo.com/user9389813/videos
opus jody
Yay, all done for now.
As expected, it got a bit confusing, but now, out of 3 there is apparently 2 fully working. during: after, mixer 1 at the back, with 6 x mic/line channels, and 2 x phono/line channels, in a live desk type set up, with the longer faders, and un-padded for maximum quality. then in the front, number 2, in DJ mode, with shorter faders, 2 phono/line channels on each side of the central output section, and 2 x mic/line channels for mics or laptop type lives on each end. i've padded all the central 4 for the dj's, and left the outside ones unpadded for more mic control, and any CD dj's i trust with levels: oh, and number 3. hmmm. £offers anyone? I'm off to test the number 2 this weekend, and probable at notting hill next weekend, so i'll be back later with the real life test results. see ya. Edited by opus jody - 07 November 2010 at 11:10am |
The Builder
Old Croc Joined: 03 January 2010 Status: Offline Points: 3107 |
Used these lots in Ibiza, 1990ish.
I loved them. No crossfaders then, not even in Space IIRC.
opus jody
TBH the crossfaders are so 'snappy' that they must be intended for crabs & lobsters(!) or whatever. but then the real scratchers would want a different mixer, i would have thought. need variable slopes really.
opus jody
Gig went well. the mixer was solid. totally well behaved.
1st act was bizarrely 2 violins & a talking drum player. I needed phantom power for the DI's for the violins, so that was a result, actually having phantom power on the dj mixer! it's nice to be able to say 'yes, no problem'. I played some phat electro basslines & hi hats (pulled out the mid) over the top of them, and it really kicked the party off. electro folk. coool I didn't like the push button crossfader assign. some of the DJ's messed them all up, and i had to reset them all at least 3 times. the only other FAIL was having channel mute buttons just under the cue/PFL buttons. there was some very confused looking dj's at some points. pissed up djs just don't need buttons on the control surface that can mess the sound up. I think what i'm going to do is see if i can cut/sand down the crossfader assign & channel mutes so that they don't protrude out from the mixer. they'll still work, but will need to be pushed with a pointy thing (technical term) like the headphone jack. Speaking of headphone jacks, putting an extra headphone socket on the front edge of the mixer was definitely a good move. no problems with a dragging the cable over the mixer causing havok with the faders. Other than those problems, it was ace. really dependable levels. no distortion even when abused. the mic pre's sounded great with the violins, although i haven't tried proper voices yet. i'll do a test with a Neuman condenser next week. When testing the mixers I found a hell of a lot of noise & static on one, then the 2nd, then checked the 1st one again. still there. PSU? Ahhh, groundlift switch. mUUUUch better. really quiet now. That is what was messing up the midrange in the earlier tests. I got to test it on the rig last night, no music, but all faders & masters up. really quiet. better than my vestax which has a 'SHHHHHHHHH' sound when you turn everything up to max. that might well tip the balance on sound quality. This week I'll have another go against the V6, and the vestax, and some other mixers that are at the factory. this time through a big rig as well as the opus test rig. with warm PSU this time too. I'll try & get some pics this time. I'll put the mixer through the spectrum analiser too, so i can see where the EQ's operate. it is different to the vestax EQ's, which operate more like a crossovers level controls, ie frequency band level controls. the Sclat's mid bands low pass is possibly a touch too high, as when you cut the top, there's still a touch of hi hat going on. So, a few more mods to try, a bit more testing against other mixers, a bit of measuring, a studio test, then some conclusions. see ya. Edited by opus jody - 07 November 2010 at 11:14am |
The Builder
It just is.
stereo
Registered User Joined: 19 March 2004 Status: Offline Points: 238 |
opus jody
hi 'stereo'.
did you get the fx section with yours? I'm intrigued to know if it will work in the 100's. more reviewing to follow shortly. |
stereo
nope,no effects on mine
Louder than loud
Old Croc Joined: 13 May 2010 Location: Guildford Status: Offline Points: 2377 |
nice
Louder than loud
Bet the DJM boys go mad about it
opus jody
i'm probably quite lucky in that i have a day job, so i don't need to take every job available, so I don't generally do gigs which involve DJM's.
So, to continue... I found a great solution to the mute/crossfader assign button problem. on careful inspection I found that the offending buttons can just be pulled off with a pair of pointy plyers, leaving the base of the switch neatly just below the surface of the mixer. The switches can still be switched quite easily with a suitable pointy thing, like the smaller of the stereo headphone jacks normally found under the minijack-normal sized jack adapter on most headphones. consequently the mixers can quite easily be set up as required in advance, and switches switched as required. So crossfaders can be assigned, or bypassed, and not messed with if you're not there. extra channels can also be muted, to protect against any MC's that decide to plug themselves in whilst you're not looking. ideal! problem solved. I took them both out to a 2 room techno gig, which went really well, but for a couple of minor problems: one of the crossfaders vanished inside the mixer! obviously I hadn't done the 4 screws up tight enough! luckily it was somewhere in the middle position, so it didn't affect mixing with the vertical faders. the other problem was with one of the channel strips on the other mixer. for some reason, when rammed up to the top, the sound went really loud, scaring the s*** out of a few people! I'm guessing the switch that switches between +/_ 5dB and +/_ 15dB was dodgey, or dirty. not too much of a problem though - there's plenty more channels after all. i just plugged into the next door channel. it was right at the end of the night, and no harm done. I measured the eq's on the analizer, and the mid & top eq's do indeed overlap quite a bit. I'm guessing that the curves were chosen to give a flat response when all eq's are at the centre dent. after a bit of playing on the mixer I did get used to it. it's just not what I was used to. it's really noticable that boosting eq's doesn't mess the sound up, making it a very forgiving mixer when abused, and giving you a lot of scope for sound shaping when used properly. I've had a good go in my makeshift studio now, and really like all the mic inputs. really useful for putting mono sources into a channel without having to make up mutant splitter leads. eg, kick drum comes out of an assigned out of my sampler/sequencer, into a mono compressor, then into a mic channel via a DI box (powered by the mixers phantom power). mono synth doing basslines goes into the other channel of the compressor, and into another mic channel. aaaand, the uber fisherprice xylophone benefits from lovely powered condenser mics, aux sent to delays & reverbs. it really does do everything i wanted of it. ideal. I'll probably sell one of them, and look at getting the 3rd one up & running. it only needs a bunch of faders. I might possibly cut the chassis down, and make a 4 or 5 channel one for tight spaces, and leave me a few spare channel strips, just in case. cheers. |
