Ecler smac pro20- Anybody got SMD-Soldering tips? |
Bams
Young Croc Joined: 08 April 2009 Status: Online Points: 622 |
Posted: 24 September 2020 at 6:08pm |
As part of my nobudget retro covidbuild system i bought a broken ecler smac pro 20. Great little mixer with usefull eq and isolators and a decent soundquality. Everything works as a charm except for the two outputs. Record out functions as normal. The outputs only emit some continous noise. There is no mysterious blue smoke or traces of burn to be seen. In the signal path of the outputs is a tl074c opamp.
Would it be an educated guess that one is broken due to the fact both channels and both outputs emit the same noise? And otherwise how can i measure such device? Edited by Bams - 30 October 2020 at 8:03am |
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
If Phones output also still works, while listening to Master output ( no Pfl engaged ), it's even certain that TL074 is bad, because no other active component(s) come after the point where the Phones signal taps off ( just before both Master Volume 1 & 2 potmeters ).
I'm sure you can easily manage without the Service Manual, but send me a PM if you like to have it anyway. |
Bams
Thank you for the confirmation! Feeling a little bit Proud due to the fact its all self-taught :)
Bams
Parts are underway, including soldering paste and heatresistant tape. But last time i did some SMD-soldering was during an apprenticeship mid-nineties. Anybody got any do’s and dont’s regarding this technique? It has to be done with a regular soldering station and/or heatgun...
Xoc1
Registered User Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 397 |
Hopefully your solder station is temperature controlled and the paste you have acquired is the 60 40 type solder, not lead free which is harder to work with. I would cut out the body of the faulty chip with small pair of wire cutters. Then remove the individual legs with a fine tipped soldering iron - ( A bit of extra solder - flux can help) . Clean up the pads with some solder wick braid. Layer some solder paste on the pads and place the new IC in situ with tweezers. Tack the end legs first making sure that the alignment is good. Then solder the rest of the pads making sure that the solder flows cleanly and check for any solder bridges. If you are unsure about your soldering a bit of side pressure on the individual legs with a fine point can confirm if its stuck down or not. Good lighting & a magnifier will help. Dependent on your eyesight. I used to do a lot of hand soldering of SMD parts - down to 40 pins per inch for processor chips. If the parts in the Smac are the same sort of size as the Sclat then they are fairly chunky by modern standards!
Bams
Thanks for the tips! Temperature comtrolled station- check! Correct solder and flux-check! And indeed, it isn’t really microsized. More like a small regular part or really chunky smd :) leave that to the spanish ;)
