  New Posts New Posts RSS Feed - ɤɤɤ Show Off Your Custom Subwoofer(s) ɤɤɤ
 Post Reply Post Reply Page  <1 2345>
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 2:01am
Those look mean. Kinda klingon style bracing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 7:03am
They look quite a bit like an Incubus Sub to be honest! Sure they sound great though, using up all that cone mass and RMS power for a higher tuning probably kicks the teeth out of the heads of the front row!
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 2:56pm
4 x 15 per cab?
Mykey Wattco
Darkstar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 3:15pm
My guess would go on 2x21".
They do look awesome, but they do also look incubus like. Not saying that's bad though. Smile
Bass =/= Enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 3:21pm
2 x 21" in a cab that stands 750mm high?
108.5 db 1w 1m?
how was it measured?
Mykey Wattco
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 3:46pm
Well 21" inches is approx 550mm Smile
Bass =/= Enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2015 at 6:08pm
2 x 15'' is 750
He mentioned rock music. 15's it would be
Mykey Wattco
RosscoPico View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RosscoPico Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2015 at 9:05pm
@b grade - Klingon bracing you say Big smile thanks, am glad it has an alien kind of look!
@Toastyghost - that's correct in that we have tuned them higher for more attack for mostly rock band related use.  Would you say the similarities you see with the Incubus are due to the styling of the bracing, the overall cabinet design, or both?  The design is actually an adaption of a slimmer version of what we had deigned long before the Incubus (you'll have to take my word for it though) and utilises 2 x 18" drivers.
@KidCreole - we get an average of sensitivity by taking readings every 10Hz between 50 - 150Hz on a dB meter. This is at 100w @ 10m.
Edited by RosscoPico - 20 July 2015 at 9:08pm
.:ELEMENT 5 SYSTEMS:.
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2015 at 12:59pm
Better to do every 1/x of an octave rather than fixed increment - your method will put proportionally more measurements in the upper part of the response, where a lot of horn based systems are more efficient, so that can skew the resulting calculated value away from what's realistic.
HTH,
David.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2015 at 2:32pm
@Toastyghost - that's correct in that we have tuned them higher for more attack for mostly rock band related use.  Would you say the similarities you see with the Incubus are due to the <span style="line-height: 16.7999992370605px;">styling of the</span> bracing, the overall cabinet design, or both?  The design is actually an adaption of a slimmer version of what we had deigned long before the Incubus (you'll have to take my word for it though) and utilises 2 x 18" drivers.
@KidCreole - <span style="line-height: 16.7999992370605px;">we get an average of sensitivity by taking readings every 10Hz between 50 - 150Hz on a dB meter. This is at 100w @ 10m.</span>
Not just the bracing, but the port positioning, bracing point, flare rate, etc!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2015 at 5:53pm
Originally posted by KidCreole KidCreole wrote:
2 x 15'' is 750
That would mean 4x15", I believe it would be kind of a big box for 15"s and it probably wouldn't weigh 150kg if that was the case. Anyhow, we're both wrong, it's a 2x18". LOL
I just thought about 21"s for the similarity with the Void boxes.
I'm pretty sure no one here believes you have copied anything Ross, I think sometimes going in the right direction leads to having similar results as others.
Bass =/= Enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2015 at 6:06pm
They all just look like big ugly boxes to our wives.
