  New Posts New Posts RSS Feed - eighteensound designs
KlaasBlackPaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KlaasBlackPaw Quote  Post ReplyReply Direct Link To This Post Topic: eighteensound designs
    Posted: 15 November 2023 at 12:40pm
Hello and Greetings everyone
I was wondering if anyone was in the know of Scoop plans for the eighteensound 18LW2420 (updated model of the 18LW2400) or eighteensound 18LW2600 woofers?
Edited by KlaasBlackPaw - 16 November 2023 at 1:19pm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 10:32am
I was wondering if anyone was in the know of Scoop plans for the eighteensound 18LW2420 (updated model of the 18LW2400) or eighteensound 18nlw4500 woofers?
I would suggest, 18LW2420, would be more optimal, in a reflex cab, and I actually have 4x in reflex cabs.
Any particular reason you are choosing 18nlw4500?
Be aware, it has cutout of 422mm and depth of 233mm.
Also be aware, it has a  no of 1.8, which means it really will require more power, for desired SPL, than many other drivers.
Edited by levyte357- - 16 November 2023 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KlaasBlackPaw Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 1:08pm
Ah Levyte, I was hoping to find a reply from you on here :)
The reason I suggested LW2420 or NLW4500 is because both are suitable for hornloaded applications, and have the xmax/freq range desired.
I'm a total newby when it comes to designing / reading T/S parameters so I just chose based on the parameters I knew / woofers I knew.
So even though the LW2420 are suitable for hornloaded applications, you'd suggest putting them in BR?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KlaasBlackPaw Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 1:19pm
Ah I see my fault, it meant to say 18LW2600, not the NLW4500***
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2023 at 2:10pm
OK, the 18LW2600 t/s parms, definitely suggest, it would be optimal in right Scoop.
This would be a great starting point, for a cab for this driver, but, needs mods, so driver will fit, with sufficient rear clearance.
Edited by levyte357- - 17 November 2023 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2023 at 8:57pm
Lev, why do you think 2420 is not good for scoops?
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2023 at 10:04pm
is there a suggested design online for that driver on the 18sound site? have a butchers
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2023 at 1:49pm
Obviously different people desire different response from their Scoops.
Think Rog actually said it initially , and my modelling confirmed it, and Mykey actually said it.
BL approx 25, will give you pretty flat response in Scoops, High BL >= 30, gives you the 40hz bang, flattened out by stack of 2x - 4x.
This is possible reason many used to say, in Scoops, Fane 18XB was more musical than 1850, more warm sounding, but not the killer 40hz bang.
Also the EBP of < 100, also suggests better in a reflex.
Edited by levyte357- - 18 November 2023 at 1:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2023 at 2:02pm
Do you think Martin Audio were idiots when they put 18TBX100 in the last generation of the WSX? Or the D&B Audio at their B2? Or many many other professionals?
2420 is more modern variant than 18TBX100.
I remember the days when you said 18NLW9601 is not good for scoops :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2023 at 3:07pm
Think people who use FLH, are looking for different sound, to those who use Scoops.
Scoops dudes prioritize huge sensitivity @40hz, with sub warmth, FLH fans prefer clean, uniform response.
Reggae Scoop dudes, will use Pre-amp to shape sub, FLH dudes tend to stick with just Mixer and LMS.
I actually use LMS and bass pre, to shape Scoop sound.LOL
Also 18NLW9601, is a Rolls Royce sub driver, but really needs substantial power input, and right sub shaping to get "warm" sound.
Edited by levyte357- - 18 November 2023 at 3:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2023 at 12:06pm
Also you will find feedback from many people, who built their own WSXs, and loaded them with Void V18-1000, reported superior performance, than original cabs with original drivers.
Response would not be as uniform 30-100hz, but 40-50hz would have substantial peak,due to V18-1000 30+ BL.
