  New Posts New Posts RSS Feed - EM Acoustics DU-1204 badged CIARE 12.00SW
eldiablo04 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eldiablo04 Quote  Post ReplyReply Direct Link To This Post Topic: EM Acoustics DU-1204 badged CIARE 12.00SW
    Posted: 13 January 2014 at 10:28am
Hi there,
Just a heads up that Ciare appear to be sending out 12.00SW punisher drivers badged up as EM Acoustics OEM's. Was a bit of a shock when I got home after driving halfway across the country to collect some punisher cabs and unused drivers, and found they were "EM Acoustics DU-1204" !
I eventually found a tiny little 12.00SW sticker on the drivers themselves.
The drivers appear to have originally come from Lean Business according to the stickers on the box. They were in normal 12.00SW boxes and look identical other than the rear magnet badging.
Hopefully this post might save someone a few hours of hastle ringing round if they recieve drivers from the same batch.
Cheers,
Jamie
Edited by eldiablo04 - 13 January 2014 at 10:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2014 at 10:55pm
Probably used in the http://www.emacoustics.co.uk/product/i-12-compound-isobaric-ulf-subwoofer then
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2014 at 11:15pm
That is a 4x12 inch 1000W aes total power. So not a 12sw00 i guess.
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2014 at 11:18pm
Might be the excursion limited power handling. Spare parts list this same driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2014 at 1:04am
Yeah it might be.
This page was generated in 0.059 seconds.
