EM Acoustics DU-1204 badged CIARE 12.00SW |
eldiablo04 ![]() Registered User ![]() Joined: 22 March 2009 Location: Brighton Status: Offline Points: 91 |
![]() ![]() ![]() ![]() ![]() Posted: 13 January 2014 at 10:28am |
Hi there,
Just a heads up that Ciare appear to be sending out 12.00SW punisher drivers badged up as EM Acoustics OEM's. Was a bit of a shock when I got home after driving halfway across the country to collect some punisher cabs and unused drivers, and found they were "EM Acoustics DU-1204" ! I eventually found a tiny little 12.00SW sticker on the drivers themselves. The drivers appear to have originally come from Lean Business according to the stickers on the box. They were in normal 12.00SW boxes and look identical other than the rear magnet badging. Hopefully this post might save someone a few hours of hastle ringing round if they recieve drivers from the same batch. Cheers, Jamie Edited by eldiablo04 - 13 January 2014 at 10:32am |
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10640 |
Probably used in the http://www.emacoustics.co.uk/product/i-12-compound-isobaric-ulf-subwoofer then
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7623 |
That is a 4x12 inch 1000W aes total power. So not a 12sw00 i guess.
Pasi ![]() Old Croc ![]() Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2723 |
Might be the excursion limited power handling. Spare parts list this same driver.
Yeah it might be.
