eminence 18 scoop plan |
Page 12> |
jayboom08
Joined: 26 December 2010 Location: norwich Status: Offline Points: 163 |
Topic: eminence 18 scoop planPosted: 25 May 2012 at 12:54pm |
Hi there has any got a good copy of the eminence18 scoop of so cud I have a copie been looking for them for some time now and can't find the book any were thanks jay
Dub Specialist
Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3235 |
Posted: 25 May 2012 at 2:20pm |
here ill scan a better copy out mi book...
![]() ![]() Edited by Dub Specialist - 25 May 2012 at 2:20pm |
Dub Specialist
Posted: 25 May 2012 at 2:27pm |
this is a better copy man...theres a fane plan too but thay are allmost identicul same people worked design at some point in time...
![]() Edited by Dub Specialist - 25 May 2012 at 2:32pm |
jayboom08
Posted: 25 May 2012 at 2:33pm |
Are brill thanks guys going to have a little build in the sun I think thanks :)
Dub Specialist
Posted: 25 May 2012 at 2:37pm |
youll welcome my friend if you need any more plans/designs out of the Fane or Emenince books give us a shout man...no worries...
..good luck will yourl build ..great cabs...![]() also the emmy scoops do work very well too alot of people wood still agree on here..
![]() Edited by Dub Specialist - 25 May 2012 at 2:41pm |
Ras Loud
Joined: 08 January 2012 Status: Offline Points: 755 |
Posted: 09 July 2012 at 12:07am |
Which drivers are people using in these except the Sigma and Omega?
I know PD's do not fit in because of their size. But how about RCF and Void drivers? Do they fit and how does it sound? |
mans1000
Joined: 14 October 2004 Location: Slough Status: Offline Points: 1373 |
Posted: 09 July 2012 at 1:24am |
I have what I'm sure are original MDF Emmy scoops. Had Wembley B-lines, Omega Pro's, Fane Sovereign Pro's in them(all 800w). They didn't like the B-lines, both the others sounded tight n heavy, but I think the Omega pro's dropped lower.
"The earth provides enough to satisfy every mans needs...but not every mans greed."
Meat
Joined: 05 June 2009 Location: Manc Status: Offline Points: 1513 |
Posted: 09 July 2012 at 7:15am |
Fane 18XB is fantastic is those.
thepastor
Joined: 10 December 2009 Status: Offline Points: 100 |
Posted: 10 July 2012 at 12:13pm |
isn't true: pd fit perfectly in eminence scoop ... mine is loaded with 1850! |
Ras Loud
Posted: 16 June 2017 at 3:31pm |
There seems to be a mistake in the second picture that Dub Specialist posted. The left anchor point for G is too far to the right. The first picture looks correct. That one is also with the new driver names, so it must be from a later edition of the book.
Edited by Ras Loud - 16 June 2017 at 3:36pm |
Dub Specialist Sound
Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4871 |
Posted: 16 June 2017 at 11:45pm |
Originaly correct, that what give emeimnce the negative expansion, what its known for
Ras Loud
Posted: 23 June 2017 at 1:08am |
Are you sure that the older version is correct and in the later edition the mistake slipped in? First I thought that a good publisher would improve new editions instead of doing the opposite. But of course, it could have also happened that they copied it wrong when making a new layout of the pages. On Freespeakerplans there is a version that has still the old driver names, but the same anchor point as the blurry picture above with the new driver names. The file has been there since 2009. That is why I am surprised that nobody has ever paid attention to this point yet. PDF Download Picture from the PDF ![]() ![]() Furthermore Aggressive Audio from South Africa uploaded this model on 3D warehouse in 2014 Sketchup file download It is clearly the same as in Dub Specialist's scan. Does the negative expansion actually get lost or does it only become less with the slightly different horn? I thought in simple words negative expansion is just that the part before the horn is smaller and then it becomes bigger again. But there are people on this forum who know much, much more about horns than me. Horn path in the version from Dub Specialist and Aggressive Audio 98 mm (distance between baffle behind the driver and bottom of the front chamber) 158 mm (smallest distance between baffle and horn) 257 mm (longest distance between baffle and horn) 175 mm (distance between horn and top side) 170 mm (smallest distance between horn and back side) 347 mm (longest distance between horn and back side) Horn path in the version from Freespeakerplans 98 mm (distance between baffle behind the driver and bottom of the front chamber) 150 mm (smallest distance between baffle and horn) 240 mm (longest distance between baffle and horn) 180 mm (distance between horn and top side) 187 mm (smallest distance between horn and back side) 347 mm (longest distance between horn and back side) Edited by Ras Loud - 24 June 2017 at 4:46am |
Page 12> |
