  New Posts New Posts RSS Feed - Eminence Alpha 15A (Double Fifteen) playing Reggae
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2015 at 2:43am
What you are prescribing sounds more to wards software embedded in an amplifier’s DSP.
Best Regards,
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 26 February 2015 at 9:23am
Yes similar for sure, ultimately I do want to make measurements over real world conditions and time spans. Acquiring the data and then processing using a PC would give a lot more flexibility than an onboard amplifier DSP I would have thought (curve fitting and parameter extraction etc). Certainly it allows you to brute force algorithms to an extent when prototyping and enables logging of data.
It's just a bit of fun really but right now I have a CNC to finish and a somewhat complicated analog filter to design and build too, then a distinct possibility of having to move house. So maybe when all that is done.
