eminence delta 15 plots |
| Author | ||
nuclearbass
Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
Topic: eminence delta 15 plotsPosted: 01 January 2013 at 6:01pm |
im oing to make 2 xm15s and load them up with deltas and use them as monitors for djs, on a budget so thought id give the deltas a try, heres the results
![]() can any one recomend a budget comp and horn that would work well?? im going to be running them via the x over in my rack so dont need an internal one
one life - have fun!
Force fusion pro audio |
soundchippy
Joined: 09 September 2011 Location: Tavistock Status: Offline Points: 770 |
Posted: 01 January 2013 at 6:51pm |
That sim is wrong. The correct Vb & Fb is stated on the plans.
Edited by soundchippy - 01 January 2013 at 6:58pm |
nuclearbass
Posted: 01 January 2013 at 7:35pm |
Ah, Thankyou, that's only 2nd time I've simmed something
Cheers again |
nuclearbass
Posted: 01 January 2013 at 7:43pm |
You've put a delta pro in there, I'll re do it with the right measurements
nuclearbass
Posted: 01 January 2013 at 7:54pm |
I don't really know how to use it all tht well, what is the cross hair for?
soundchippy
Posted: 01 January 2013 at 8:27pm |
t/s for delta pro matches those in your original plot.
crosshair makes it easier to read spl at some frequency |
nuclearbass
Posted: 01 January 2013 at 10:28pm |
