Eminence Kappa12a reflex tuning |
sushi
Registered User Joined: 27 March 2012 Location: Milan Status: Offline Points: 90 |
Posted: 22 January 2020 at 4:15pm |
Hello Everyone!
I would like to build a pair of cabs, for 2 Kappa12a and 2 PSD2002-8 that i already have at home. I developed a project for a 60 liters box, that's more or less the maximum volume indicated for the woofer (considered the volume taken by the woofer itself, the hf driver+horn and the damping material, i thought that it would work well) My problem is: I don't know how to calculate the reflex port size and depth My requirements are.. 1) Port shall be of rectangular shape, 350mm wide (cab's whole internal width) with a 15mm brace panel in the middle (so maybe port is to be considered 335mm wide.. isn't it?) 2) 50 / 55hz tuned. Kappa12a starts to loose efficiency in response under 70hz, i would like to enhance low frequencies in order to gain some bass. I tryied to use some "reflex automatic calculator" on the internet, but seriusly i don't get any understandable result. I'd rather learn how to calculate it by myself. Would someone help me with this? Best regards |
smithshorn
Registered User Joined: 08 February 2007 Status: Offline Points: 253 |
Winisd is your friend here. Probably the simplest calculator out there. Ports can be calculated for round, or square/rectangular as well.
Conanski
Download a copy of Win ISD and run a simulation.[URL=http://www.linearteam.org/
If that driver isn't already in the program(I think it is) you will have to enter the TS specs as a new file. And I suggest you don't try to get too much lowend out of those drivers, they're designed more as low/mid than a bass driver. |
sushi
Thanks a lot! I'll try to download it on my pc, hope it will solve my issues.
I won't try to get a sub from the cab, just looking for a near-fullrange performance for small indoor parties.. i've been using the kappa12a for years in a sealed cab and i know it has its limits. I'll surely put an highpass filter at 50hz. Gonna use my 18" reflex cabs if i need loud bass. |
